Gid 12 cannot run on Ubuntu 24.04
kstn
Post by kstn »
I ran gid12.0.9 on Ubuntu 24.04 and got this error:
Code: Select all
symbol lookup error: /lib/x86_64-linux-gnu/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var
Moving forward, I think it is wiser to release GiD as snap/flatpak package on Linux.
Re: Gid 12 cannot run on Ubuntu 24.04
off course not all GiD versions are compatible with all OS versions
Maybe with some trick you are able to run it.
try to set before the LD_PRELOAD environment variable pointing to your copy of the libfreetype.so library
e.g. something like
export LD_PRELOAD=/usr/lib64/libfreetype.so
.gid
or maybe installing this freetype library if it is missing or updating
