How to lock scale factor for line thickness results
tiago_valente
Post by tiago_valente »
I use the option of "Line thickness" to visualize results in line elements. In order to check the evolution of the results for different steps, I use the animation tool. I want to know if it is possible to lock the scale factor for the line thickness results because if I previously change the scale factor for a given step, the scale factor is automatically changed when the step changes.
Line thickness sclae.png (392.49 KiB) Viewed 12087 times
Re: How to lock scale factor for line thickness results
Post by miguel »
Hello tiago_valente,
the problem has been corrected for the next versions of gid. when changing the time-step or doing an animation, the sacle factor of both visualization types: line thickness and result surface will be preserved.
thanks for the report!
the gid team
