Due to my mistake Gid Default menu is disappear.
And, when open problemtype, occured error about toolbar.
I can't do Anything gid.
please help...
can't find my toolbar
- MENU DISAPPEAR.png (87.44 KiB) Viewed 8468 times
- TOOLBAR.png (216.28 KiB) Viewed 8468 times
- USING PROBLEMTYPE.png (277.47 KiB) Viewed 8468 times
- ERROR.png (308.2 KiB) Viewed 8468 times
Re: can't find my toolbar
If GiD is starting without menus, delete the user preferences file, to restore the initial defaults:
see this FAQ: https://www.gidhome.com/documents/faqgi ... references
And if you are modifying some problem type and it raise errors when loading, off course must fix these errors.
escolano wrote:If GiD is starting without menus, delete the user preferences file, to restore the initial defaults:
Thanks a lot!!!
Restoring .ini data file solved all errors and problem.
