I'm trying to save the nodal results from the postprocess to a list in TCL. In the resulting model of the analysis, I made a cut (CutPlane) where I need to know the coordinates, displacements, etc. The cuts look like two square rings (yellow and red, one under another):
I already converted them into a Set (Geometry>Convert to sets). Before I did this, the number of nodes was 413,303. And after that convertion, the number is 415,099 (I turned off some other layers, that's the reason for (413,303 + 914 yellow ring + 882 red ring=415,099), I supposed that the convertion was succesful, but, when I wanted to get the coordinates of the 413,303+1= 413,304 node with this command:
Code: Select all
[GiD_Info Mesh Nodes 413304-array -avoid_frozen_layers]
Code: Select all
What do I need to do? Could you please help me?
I already tried the Select Results window, and THIS is what I want to get (ID,XCoord,YCood,ZCoord,XDisp,YDisp,ZDisp):
