I'm new in GiD modelling
Is there any script or macro that I being able to automatically draw vertical line (i.e. in z direction) between points with same x,y in different z?
All points in different depth (z direction) have the same x and y coordinate.
Note that I don't want to use the extrude feature when copying points to another z level to draw vertical lines, because the distance between points in the last layer is not identical. In other words, points in z=0 have a 0.85 degree inclination but the ones in z=-14.8m level have zero degree inclination.
Here is the screenshot of xy and xz views:
Abolfazl
