Drawing vertical line between points with same xy in different z
najafi
Post by najafi »
Hi
I'm new in GiD modelling :) .
Is there any script or macro that I being able to automatically draw vertical line (i.e. in z direction) between points with same x,y in different z?
All points in different depth (z direction) have the same x and y coordinate.
Note that I don't want to use the extrude feature when copying points to another z level to draw vertical lines, because the distance between points in the last layer is not identical. In other words, points in z=0 have a 0.85 degree inclination but the ones in z=-14.8m level have zero degree inclination.
Here is the screenshot of xy and xz views:
Abolfazl
Re: Drawing vertical line between points with same xy in different z
It doesn't exists any tool to automatically create the lines you want.
You must create your own Tcl scripting proc that ask for the points to get its coordinates, and find the clusters of points 'close with a tolerance in x,y', sort each cluster by z and create the new lines connecting them
to ask the GiD points can use something like this
Code: Select all
foreach point_id [GiD_Geometry list point] {
   set xyz [lrange [GiD_Geometry get  point $point_id] 1 3]
   set coordinates($point_id) $xyz
and can create a new straight line knowing the ids of its endpoints with
Code: Select all
set layer [GiD_Layers get to_use]
GiD_Geometry create line append stline $layer $ini_point $end_point
najafi
Post by najafi »
Thank you so much.
I'll try it and let you know the result.
This is a complete code to create the lines joining vertical points-np
to be used can for example save to a .tcl file, like C:/temp/CreateVerticalLines.tcl and load it in GiD writting
-np- source C:/temp/CreateVerticalLines.tcl
and then invoke the creation proc with
-np- CreateVerticalLines
Code: Select all
#for a big amount of points the bruteforce search O(n^2) will be too expensive
#can use some spatial search like vtkKdTree O(n log n) (see <GiD>\plugins\Geometry\voro\voro.tcl as example)
proc FindVerticalPointsBruteForce { coordinates_dict point_start_id tolerance2 } {
    set vertical_point_ids [list]
    set xy [dict get $coordinates_dict $point_start_id]
    foreach point_id [dict keys $coordinates_dict] {
        if { [MathUtils::VectorDistance2 $xy [dict get $coordinates_dict $point_id]] <= $tolerance2 } {
            lappend vertical_point_ids $point_id
    if { [llength $vertical_point_ids] > 1 } {
        #sort by z increasing
        set vertical_points_and_z [list]
        foreach vertical_point_id $vertical_point_ids {
            set z [lindex [GiD_Geometry get  point $vertical_point_id] 3]
            lappend vertical_points_and_z [list $vertical_point_id $z]
        foreach item [lsort -index 1 -real $vertical_points_and_z] {
            lappend vertical_point_ids [lindex $item 0]
    return $vertical_point_ids
proc CreateVerticalLines { } {
    set coordinates_dict [dict create]
        set xy [lrange [GiD_Geometry get  point $point_id] 1 2]
        dict set coordinates_dict $point_id $xy
    set layer_to_use [GiD_Layers get to_use]
        if { [dict exists $coordinates_dict $point_id] } {
            set vertical_point_ids [FindVerticalPointsBruteForce $coordinates_dict $point_id 1e-25]
            set ini_point ""
            foreach end_point $vertical_point_ids {
                if { $ini_point != "" } {
                    GiD_Geometry create line append stline $layer_to_use $ini_point $end_point
                set ini_point $end_point
            #remove from coordinates_dict the points already clustered
                dict unset coordinates_dict $vertical_point_id
    GiD_Redraw
