problemtypes are placed under the subdirectory, in Roaming\GiD\16.1.6d\problemtypes\SomeCompany\
Posted: Tue Nov 21, 2023 4:24 am
by Hemmi
I am using GiD16.1.6d on Windows11Pro.
I wanted to place some problemtypes at the directory, that is,
C:\Users\<your_windows_user>\AppData\Roaming\GiD\16.1.6d\problemtypes
If unzip testOK.zip, and start GiD16.1.6.d. GiD can handle problem types properly.
Please remove all files just unzipped.
And then, if unzip testERROR.zip, in which my problemtypes are placed under the subdirectory SomeCompany/, and start GiD16.1.6.d. There arises an error:
Error: window name "m0" already exists in parent.
Another related issue:
If some directory is "permission denied", immediate fault occurs.
Re: problemtypes are placed under the subdirectory, in Roaming\GiD\16.1.6d\problemtypes\SomeCompany\
Posted: Fri Dec 22, 2023 6:45 pm
Hi Hemmi,
Thanks for your bug report
It has been fixed for next 16.0.8 official and 16.1.9d developer versions
Unfortunately this detail is not fixed in current versions 16.0.7 and 16.1.8d that we have published today.
In any case I recommend strongly to update to latest versions to avoid problems with old fixed bugs.
Posted: Mon Jan 08, 2024 4:05 am
by Hemmi
The error I reported has not been corrected for both GiD16.07 and GiD16.1.8d.
'Application Error'
'Error window name "m0" already exists in parent'
Please check again.
wrote on Mon Jan 8 12:03:44 JST 2024.
Posted: Mon Jan 08, 2024 12:25 pm
Yes, re-read my message, I said that was fixed after these versions.
16.0.8 official and 16.1.9d developer versions are the future versions
