Number of divisions in a single line or surface
parduino
Post by parduino »
When using structured meshes, is it possible to get the number of divisions used in a single line or surface?
As is the Draw command in Mesh does not allow a clear identification of the particular # of divisions in specific lines or surfaces.
Maybe there is an alternative way to get this info for a large model.
Re: Number of divisions in a single line or surface
For example, if do you list a line (Utilities->List->Lines)
then if the line has set as meshing number of divisions (e.g. indirectly because you have set its surface as structured) you will see a field
"IsStruct" to 1 and another field "Num Cells" ​with this integer number of divisions.
