Abaqus import (*.inp file)
fcdiass
Post by fcdiass »
I would like to know how to use correctly the option "Files > Import > Abaqus..." available since version 14.1.8d (developer version).
In version 14.1.8d when I choose this option, a window opens and I can choose files with *.inp extension. A kind of code runs, and in the end I can't see the mesh anywhere.
In version 14.1.9d when I choose this option, I can do the same as the previous step, but in the end, I receive an error message.
What I am doing wrong?
PS: Next, I present the contents of the "test.inp" file, in case someone wanted to reproduce my steps.
Code: Select all
*Heading
** Job name: Job-1 Model name: Model-1
** Generated by: Abaqus/CAE 2017
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
      1,           0.,           0.
      2,  0.200000003,           0.
      3,  0.400000006,           0.
      4,  0.600000024,           0.
      5,  0.800000012,           0.
      6,           1.,           0.
      7,           0.,  0.200000003
      8,  0.200000003,  0.200000003
      9,  0.400000006,  0.200000003
     10,  0.600000024,  0.200000003
     11,  0.800000012,  0.200000003
     12,           1.,  0.200000003
     13,           0.,  0.400000006
     14,  0.200000003,  0.400000006
     15,  0.400000006,  0.400000006
     16,  0.600000024,  0.400000006
     17,  0.800000012,  0.400000006
     18,           1.,  0.400000006
     19,           0.,  0.600000024
     20,  0.200000003,  0.600000024
     21,  0.400000006,  0.600000024
     22,  0.600000024,  0.600000024
     23,  0.800000012,  0.600000024
     24,           1.,  0.600000024
     25,           0.,  0.800000012
     26,  0.200000003,  0.800000012
     27,  0.400000006,  0.800000012
     28,  0.600000024,  0.800000012
     29,  0.800000012,  0.800000012
     30,           1.,  0.800000012
     31,           0.,           1.
     32,  0.200000003,           1.
     33,  0.400000006,           1.
     34,  0.600000024,           1.
     35,  0.800000012,           1.
     36,           1.,           1.
     37,           0.,   1.20000005
     38,  0.200000003,   1.20000005
     39,  0.400000006,   1.20000005
     40,  0.600000024,   1.20000005
     41,  0.800000012,   1.20000005
     42,           1.,   1.20000005
     43,           0.,   1.39999998
     44,  0.200000003,   1.39999998
     45,  0.400000006,   1.39999998
     46,  0.600000024,   1.39999998
     47,  0.800000012,   1.39999998
     48,           1.,   1.39999998
     49,           0.,   1.60000002
     50,  0.200000003,   1.60000002
     51,  0.400000006,   1.60000002
     52,  0.600000024,   1.60000002
     53,  0.800000012,   1.60000002
     54,           1.,   1.60000002
     55,           0.,   1.79999995
     56,  0.200000003,   1.79999995
     57,  0.400000006,   1.79999995
     58,  0.600000024,   1.79999995
     59,  0.800000012,   1.79999995
     60,           1.,   1.79999995
     61,           0.,           2.
     62,  0.200000003,           2.
     63,  0.400000006,           2.
     64,  0.600000024,           2.
     65,  0.800000012,           2.
     66,           1.,           2.
*Element, type=CPS4
 1,  1,  2,  8,  7
 2,  2,  3,  9,  8
 3,  3,  4, 10,  9
 4,  4,  5, 11, 10
 5,  5,  6, 12, 11
 6,  7,  8, 14, 13
 7,  8,  9, 15, 14
 8,  9, 10, 16, 15
 9, 10, 11, 17, 16
10, 11, 12, 18, 17
11, 13, 14, 20, 19
12, 14, 15, 21, 20
13, 15, 16, 22, 21
14, 16, 17, 23, 22
15, 17, 18, 24, 23
16, 19, 20, 26, 25
17, 20, 21, 27, 26
18, 21, 22, 28, 27
19, 22, 23, 29, 28
20, 23, 24, 30, 29
21, 25, 26, 32, 31
22, 26, 27, 33, 32
23, 27, 28, 34, 33
24, 28, 29, 35, 34
25, 29, 30, 36, 35
26, 31, 32, 38, 37
27, 32, 33, 39, 38
28, 33, 34, 40, 39
29, 34, 35, 41, 40
30, 35, 36, 42, 41
31, 37, 38, 44, 43
32, 38, 39, 45, 44
33, 39, 40, 46, 45
34, 40, 41, 47, 46
35, 41, 42, 48, 47
36, 43, 44, 50, 49
37, 44, 45, 51, 50
38, 45, 46, 52, 51
39, 46, 47, 53, 52
40, 47, 48, 54, 53
41, 49, 50, 56, 55
42, 50, 51, 57, 56
43, 51, 52, 58, 57
44, 52, 53, 59, 58
45, 53, 54, 60, 59
46, 55, 56, 62, 61
47, 56, 57, 63, 62
48, 57, 58, 64, 63
49, 58, 59, 65, 64
50, 59, 60, 66, 65
*Nset, nset="Rock 1", generate
  1,  66,   1
*Elset, elset="Rock 1", generate
  1,  50,   1
** Section: Section-1
*Solid Section, elset="Rock 1", material="Rock 1"
1.,
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Nset, nset=Loads, instance=Part-1-1
 61, 66
*Nset, nset=Set-3, instance=Part-1-1
 1,
*Nset, nset=line, instance=Part-1-1, generate
 1,  6,  1
*Elset, elset=line, instance=Part-1-1, generate
 1,  5,  1
*End Assembly
** MATERIALS
*Material, name="Rock 1"
*Elastic
 3e+07, 0.2
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Displacement/Rotation
*Boundary
line, 2, 2
** Name: BC-2 Type: Displacement/Rotation
*Boundary
Set-3, 1, 1
** STEP: Load
*Step, name=Load, nlgeom=NO
Load
*Static
1., 1., 1e-05, 1.
** LOADS
** Name: Loads   Type: Concentrated force
*Cload
Loads, 2, -100.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
Re: Abaqus import (*.inp file)
There is an small bug in the Abaqus mesh import plugin v 0.1
I attach an
Abaqus.zip
(4.59 KiB) Downloaded 919 times
with a fixed 0.2 version
To use it must simply unzip at "<GiD>\plugins\Import\pre", replacing the current one.
You can see the content of the zip, there are two text files, the .xml with declarations of the plugin, and the .tcl with the scripting code to read the .inp files and create the mesh.
Your example could be read without problems with this plugin version.
If do you have problems with other examples send us a copy (can be sent privatelly if necessary)
Next GiD versions will include the updated plugin,
samll
Post by samll »
[quoteThere is an small bug in the Abaqus mesh import plugin v 0.1
I attach an Abaqus.zip with a fixed 0.2 version
Next GiD versions will include the updated plugin,[/quote]
wow
really handy addon
I was looking for some workaround and found a gold plugging
thanks a lot
My latest project called Lead Network, and it's my personal take on the world of personal finance and stuff
Chambernan
Post by Chambernan »
Hello! I want to import an ABAQUS .inp file, the type of element is C3D10. GiD verson is 14.0.1.
When I try to import, there is an error:
GiD_Mesh -- node '1' already exists
while executing
"GiD_Mesh create node $node_id [list $x $y $z]"
(procedure "Abaqus::ReadPreMesh" line 75)
invoked from within
"Abaqus::ReadPreMesh $filename"
(procedure "Abaqus::ReadPre0" line 15)
invoked from within
"Abaqus::ReadPre0 $filenames"
(procedure "Abaqus::ReadPre" line 5)
invoked from within
"Abaqus::ReadPre E:/ABAQUS2018/temp/practice/Job-1.inp"
("eval" body line 1)
invoked from within
"eval $args"
(procedure "GidUtils::EvalAndEnterInBatch" line 3)
invoked from within
"GidUtils::EvalAndEnterInBatch Abaqus::ReadPre $filenames"
(procedure "Abaqus::ReadPreW" line 9)
invoked from within
"Abaqus::ReadPreW"
(menu invoke)
This is my inp file
Could you please help me? Thank you!
Job-1.zip
(243.82 KiB) Downloaded 650 times
Chambernan
Does this mean that only one part can be imported at a time?
You are right, the plugin Abaqus 0.2 was not prepared for multiple parts that use for each part the same local ids for nodes and elements, and then become repeated ids.
Now we have implemented it:
Simply unzip this file
Abaqus.zip
(5.03 KiB) Downloaded 680 times
with the version 0.3 or the abaqus plugin in the folder <GiD>/plugins/Import/pre
replacing the previous copy.
Chambernan
Thank you very much! This version is OK. Excellent!
Chambernan
Hello! I used the plugin Abaqus to import the mesh. I created two sets (for the same part) in Abaqus by defining the keywords *Nset and *ELset. I want to store the information of the elements and nodes of these two sets in two layers, so as to define different properties. Can it be achieved by modifying Abaqus.tcl?
I also thought of another way. Through layer->send to->element, then by command. This can be achieved by entering the element number. But if there are many elements in the set, it is very troublesome. Can it be achieved by a command? For example, "1, 10, 1", to select elements 1~10.
Thank you!
In fact I have already implemented a new version 0.4 of our Abaqus plugin that use the Nset and Elset Abaqus information and assign them to GiD groups
The group concept similar to layer, but an entity can belong to more than one group but is limited to belong to one layer (and the groups window contextual menu has an option to create+assign layers from groups and vice-versa)
If you install GiD 16.1.0d (the current last developer version it has this Abaqus plugin 0.4 version)
I attach also a copy here:
Abaqus-0.4.zip
(5.71 KiB) Downloaded 651 times
And about the selection of GiD, in a command that is requiring a selection you can specify it with this syntax
1:10 25 27
to mean from 1 to 10 and the 25 and 27
there are more other selection syntax with filters, e.g. to select the entities of a layer can write
layer:<layername>
Read this page of the 'reference manual': https://gidsimulation.atlassian.net/wik ... +selection
Chambernan
Thank you! I will try.
