[GiDlist] Post Processing Results on Guass Points
Farzam, Arash
Post by Farzam, Arash »
I have developed this post processing file, but I am not able to use the
GiD post processing data demonstration for the data that are on Gauss
points. Please let me know if there is any problems.
Arash
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.obj
Type: model/mesh
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.msh
Farzam, Arash
I would like to ask if you can help me with this issue.
Arash Farzam
On Fri, Sep 27, 2013 at 3:53 PM, Farzam, Arash
Arash
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/e7038017/attachment.htm
Farzam, Arash
Attached, please find the files.
On Fri, Oct 4, 2013 at 10:47 AM, Farzam, Arash
Arash Farzam
Arash
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/ec932811/attachment.htm
Type: application/zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/ec932811/attachment.zip
anna
Post by anna »
Dear Arash,
Your .res file is not including the Gauss points definition header.
Please find the header structure in this link
http://www.gidhome.com/component/manual/customizationmanual/postprocess_data_files/postprocess_results_format-_projectnamepostres/gauss_points
farzam at ostatemail.okstate.edu mailto:farzam at ostatemail.okstate.edu
Arash Farzam
to use the GiD post processing data demonstration for the data
that are on Gauss points. Please let me know if there is any
problems.
Arash
*Anna Monros Bellart*
AVISO IMPORTANTE
AVÍS IMPORTANT
del CIMNE. Es poden exercir els drets d'accés, rectificació,
cancel•lació i oposició, per escrit a les nostres oficines del CIMNE,
IMPORTANT NOTICE
Do you have two errors:
1- in the .msh file your definition of gauss points is wrong:
You not must to define the global position of your (n_elem x n_gauss_by_elem) gauss points !!
what you must define is only the location of n_gauss_by_elem gauss points in a single 'reference element' (e.g. only 4 local coordinates for quadrilaterals with 4 gauss points)
and in case that you use the same locations that GiD (see Customization manual about postprocess files), then this definition is unneded, and you can use our 'standard names' for your result
(e.g. for quadrilaterals with 4 gauss points the keyword is GP_QUADRILATERAL_4)
2- in the .res file, you are using a 'gauss location name' for the result "Board Gauss Given" that is not defined in the .msh or predefined by GiD (e.g GP_QUADRILATERAL_4)
And then for each element you must write the element id and as many values as n_gauss_by_elem (4 values for GP_QUADRILATERAL_4)
Read the related Customization manual on postprocess files to know other options
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Anna Monros
Enviado el: martes, 8 de octubre de 2013 12:01
CC: Bulut, Rifat
Asunto: Re: [GiDlist] Post Processing Results on Guass Points
Dear Arash,
Please find the header structure in this link http://www.gidhome.com/component/manual/customizationmanual/postprocess_data_files/postprocess_results_format-_projectnamepostres/gauss_points
Arash Farzam
problems.
Arash
CIMNE - International Center for Numerical Methods in Engineering Campus Nord UPC - C1 building - C2 Office Gran Capità s/n - 08034 Barcelona
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán en un fichero para facilitar la gestión de las comunicaciones de CIMNE.
Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVÍS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d'accés, rectificació, cancel•lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
