[GiDlist] problems with Collapse Model
Jose Antonio Fernández Merodo
Post by Jose Antonio Fernández Merodo »
Dear GiD team,
I don 't understand why when I use the "Collapse Model" function, GiD
creates new points, lines and surfaces that complicates my initial model. I
want to mesh a topography and I m using NurbsLines and NurbsSurfaces.
In the same context, if I collapse a Model done with simple lines, these are
converted to Nurbslines, why?
Thank you for your advice.
José
___________________________________________________________
José Antonio Fernández Merodo
INSTITUTO GEOLÓGICO Y MINERO DE ESPAÑA
Departamento de Investigación y Prospectiva Geocientífica
Área de Riesgos Geológicos
c/ Ríos Rosas 23, 28003 Madrid, España
( +34 91349 5810
* mailto:jose.fernandez at igme.es jose.fernandez at igme.es
Web http://www.igme.es/ www.igme.es
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130821/ff106e7c/attachment.htm
The collapse is really doing several thinks, not only join close points,
for example It also deformate the curves if its end points were moved,
it join neighbor curves if they are ‘tangents enough’ (this require the
conversion to NURBS expression)
and it do also the opposite thing: split NURBS curves (and NURBS surfaces)
if they have an inner corner (edge for surfaces) that is not ‘tangent
enough’
(because jumps in its derivatives could cause a lot of problems for other
algorithms that expects its continuity)
This is the cause that collapsing your topographic model could increase the
amount of points, curves and surfaces
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Jose Antonio
Fernández Merodo
Enviado el: miércoles, 21 de agosto de 2013 15:21
Asunto: [GiDlist] problems with Collapse Model
Dear GiD team,
José
( +34 91349 5810
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130903/d77bf212/attachment-0001.htm
