[GiDlist] gidpost library
Jose Antonio Fernández Merodo
Post by Jose Antonio Fernández Merodo »
Ok, I found the function I need in gidpost.cpp: GiD_WriteCircleMat
De: Jose Antonio Fernández Merodo [mailto:jose.fernandez at igme.es]
Enviado el: miércoles, 13 de febrero de 2013 14:23
Para: 'gidlist at listas.cimne.upc.edu'
Asunto: gidpost library
Dear GiD team,
I m using the gidpost.lib (fortran) for a long time to create my flavia.msh
and flavia.res files. At this moment I m using "Circle" and "Sphere"
ElemType, do you know how I can write the information:
"Element_number Node_number Radius [optional_normal_x optional_normal_y
optional_normal_z] [optional_material_number]"?
GiD_WriteElementMat function is not valid for this purpose.
Thank you.
José Antonio
___________________________________________________________
José Antonio Fernández Merodo
INSTITUTO GEOLÓGICO Y MINERO DE ESPAÑA
Departamento de Investigación y Prospectiva Geocientífica
Área de Investigación en Peligrosidad y Riesgos Geológicos
c/ Ríos Rosas 23, 28003 Madrid, España
( +34 91349 5810
* mailto:jose.fernandez at igme.es jose.fernandez at igme.es
Web http://www.igme.es/ www.igme.es
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130213/a915d452/attachment.htm
Yes, the functions you ask are (C++ syntax)
int GiD_WriteSphere(int id, int nid, double r)
int GiD_WriteSphereMat(int id, int nid, double r, int mat)
int GiD_WriteCircle(int id, int nid, double r,double nx, double ny, double nz)
int GiD_WriteCircleMat(int id, int nid, double r,double nx, double ny, double nz, int mat)
Maybe the current gidpost source code of the version to be downloaded in our web page is too old, and these functions are not implemented on it.
Sent: Wednesday, February 13, 2013 4:33 PM
Subject: Re: [GiDlist] gidpost library
Dear GiD team,
I m using the gidpost.lib (fortran) for a long time to create my flavia.msh and flavia.res files. At this moment I m using "Circle" and "Sphere" ElemType, do you know how I can write the information:
"Element_number Node_number Radius [optional_normal_x optional_normal_y optional_normal_z] [optional_material_number]"?
Thank you.
José Antonio
( +34 91349 5810
* jose.fernandez at igme.es
Web www.igme.es
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130213/6672c7c3/attachment-0001.htm
