** . Now if I import this latest GiD mesh as surface mesh I end up with =
deformed surface geometry which is what I want
!!! If I omit the step of exporting the GiD mesh ** above ,which =
seems unnecessary, the import of the surface mesh brings in an =
incomplete model it appears the parts that were originally on "S Elmer =
mesh 2" (in my case for my model ) in gid post, disappear?
=20
GiD 7.7.7b on win2000
=20
regards
mark
________________________________
[mailto:gidlist-admin at gid.cimne.upc.edu] On Behalf Of Enrique Escolano
Sent: 04 February 2008 15:15
Subject: Re: [GiDlist] export deformed mesh
GiD 7.7.7b is a very old version for this rjump feature.=20
You must use one of the last beta versions (8.1.x)
(can get a temporary password for the 8.x version)
=20
Off course you can try to manually merge surfaces, but it can require a =
lot of work.
Last beta vesions include also a new command to merge surfaces with =
different algorithms (only from the boundary, or using more iformation =
from the interior)
This command is under test, and is only avaible at command line level =
(not from the menus)
=20
escape geometry edit joinsurfaces
=20
=20
From: Smith, Mark mailto:Mark.Smith at linx.co.uk =20
To: gidlist at gid.cimne.upc.edu=20
Sent: Monday, February 04, 2008 3:31 PM
Subject: RE: [GiDlist] export deformed mesh
Hi Enrique
I have tried your suggestion without success. I get the following =
error.
=20
VoidPlex::set_at. Invalid void index 0
=20
Gid then crashes!
=20
I tried it on a simple rectangle where it worked fine. What I would =
really like is for GiD to somehow merge/join surfaces together creating =
larger areas of probably higher degree?
regards
mark
=20
win2000. GiD 7.7.7b
Sent: 04 February 2008 12:19
=09
=09
Have you tried to use the 'rjump' mesher capabilities? (to create =
elements jumping between surfaces)
You can select this mesher in the meshing preferences, or you can =
manually set only some lines to be jumped or not jumped
Mesh-Mesh criteria-Skip
=20
Sent: Monday, February 04, 2008 12:34 PM
Hi GiD team
I need some advice on remeshing deformed geometry.
I have done an structural analysis using large displacement =
(triangular) shell elements, I now want to create simplified geometry =
from the deformed mesh data.
I can use Enrique's method to produce new geometry of the part with =
triangle surfaces. These triangles will on average have a lower quality =
measure than the original undeformed mesh. I can see no way of producing =
a simplified surface model from this highly faceted dxf import so that I =
can mesh again with elements of a similar size but of better shape =
quality. I can re-mesh with smaller elements but all the existing nodes =
are not moved so any poor shaped surfaces will remain? Does this imply =
that I must manually delete surface & rebuild them again?
regards
mark
Sent: 01 February 2008 12:50
=09
=09
Hello Jos=E9,
=20
It's not easy to remesh over a previous mesh (e.g a mesh deformated =
while the analysis),
=20
You can import the GiD ASCII mesh of triangles as a "Surface mesh" =
and try to remesh it
or you can import each triangle as a surface (with the trick explained =
exporting as dxf) and try to remesh this geometry (can try to use rjump =
to avoid to have one or more new elements by triangle).=20
Whit the second approach do you have several tools to edit the =
geometry to solve the problems (the surface-mesh can't be handled with =
the classical geometrical tools)
=20
From: Jose Antonio Fernandez mailto:Jose.A.Fernandez at cedex.es =20
Sent: Friday, February 01, 2008 10:33 AM
But, how can we use results of an analysis in the pre-process? Is =
there any way to do remeshing easily? (for localized failure or ALE =
algorithms for instance)
Thanks.
Jos=E9
=20
=09
De: gidlist-admin at gid.cimne.upc.edu =
[mailto:gidlist-admin at gid.cimne.upc.edu] En nombre de Enrique Escolano
Enviado el: jueves, 31 de enero de 2008 20:33
Asunto: Re: [GiDlist] export deformed mesh
=20
Hi Mark,
=20
You can export from postprocess the deformated mesh (it's written in =
GiD mesh ASCII format)
and you can read this mesh with an external program to calculate the =
enclosed volume=20
(this volume calculation from a boundary mesh is trivial )
Or you can do a macro to ask GiD about the mesh and deformation =
result and calculate the volume with a tcl procedure (but ask the mesh =
with Tcl can be slow for big meshes)
=20
If do you need to do this calculation only once for this case, as =
trick, you can import the previous GiD mesh file in preprocess again, =
then export again as dxf with the DXFSap2000 template, and import again =
in GiD to convert each triangle in a surface. Then create a volume with =
this surfaces and ask his volume.
=20
Sent: Thursday, January 31, 2008 6:55 PM
Subject: [GiDlist] export deformed mesh
=20
Hi Gidders
I've been doing some analysis of the deflections of a shelled =
container subject to an external pressure. I can view the deformed =
structure in GiD but now need to somehow make a measurement of the =
volume change. Is there anyway I can export the deformed mesh as =
geometry so I can import it into gid as geometry create a volume, then =
do utilities:list:volumes(mass) ? Or is there an even easier way?
regards
mark
This message (including any attachments) contains confidential=20
and/or proprietary information intended only for the addressee.=20
Any unauthorized disclosure, copying, distribution or reliance on=20
the contents of this information is strictly prohibited and may=20
constitute a violation of law. If you are not the intended=20
recipient, please notify the sender immediately by responding to=20
this e-mail, and delete the message from your system. If you=20
have any questions about this e-mail please notify the sender=20
immediately.
immediately.
=09
immediately.
=09
immediately.
------_=_NextPart_001_01C86C9C.CD516473
Content-Type: text/html;
charset="iso-8859-1"
!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"
HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:v =3D=20
"urn:schemas-microsoft-com:vml" xmlns:o =3D=20
charset=3Diso-8859-1"
META content=3D"MSHTML 6.00.2800.1505" name=3DGENERATOR!--[if !mso]
STYLEv\:* {
BEHAVIOR: url(#default#VML)
o\:* {
w\:* {
.shape {
/STYLE
![endif]--
STYLE@font-face {
font-family: Tahoma;
@font-face {
font-family: Verdana;
@page Section1 {size: 595.3pt 841.9pt; margin: 70.85pt 3.0cm 70.85pt =
3.0cm; }
P.MsoNormal {
FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline
SPAN.MsoHyperlink {
A:visited {
COLOR: purple; TEXT-DECORATION: underline
SPAN.MsoHyperlinkFollowed {
P {
FONT-SIZE: 12pt; MARGIN-LEFT: 0cm; MARGIN-RIGHT: 0cm; FONT-FAMILY: =
"Times New Roman"; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto
SPAN.EstiloCorreo17 {
COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal
SPAN.EstiloCorreo19 {
FONT-WEIGHT: normal; COLOR: blue; FONT-STYLE: normal; FONT-FAMILY: =
Verdana; TEXT-DECORATION: none; mso-style-type: personal-reply
DIV.Section1 {
page: Section1
/STYLE
!--[if gte mso 9]xml
o:shapedefaults v:ext=3D"edit" spidmax=3D"1026"
/xml![endif]--!--[if gte mso 9]xml
o:shapelayout v:ext=3D"edit"
/o:shapelayout/xml![endif]--/HEAD
BODY lang=3DES vLink=3Dpurple link=3Dblue bgColor=3Dwhite
DIV dir=3Dltr align=3DleftSPAN class=3D997183310-11022008FONT =
face=3DArial=20
color=3D#0000ff size=3D2Hi GiD team/FONT/SPAN/DIV
face=3DArial=20
color=3D#0000ff size=3D2I have been exploring some more with GiD on the =
subject of=20
deformed meshes & have discovered the following which is very =
useful, it may=20
be a bug or a feature I'm not sure? It may be useful to other users as=20
well?/FONT/SPAN/DIV
face=3DArial=20
color=3D#0000ff size=3D2/FONT/SPAN /DIV
face=3DArial=20
color=3D#0000ff size=3D2From postprocessor I export the deformed mesh=20
using files:export:post information:ASCII=20
files/FONT/SPAN/DIV
face=3DArial=20
color=3D#0000ff size=3D2in preprocess I import this as GiD mesh, now =
export again=20
as GiD mesh ** . Now if I import this latest GiD mesh as =
surface mesh=20
I end up with deformed surface geometry which is what I want
a mesh=20
at all !!! If I omit the step of exporting the GiD =
mesh **=20
above ,which seems unnecessary, the import of the surface mesh brings in =
an=20
mesh 2"=20
(in my case for my model ) in gid post, disappear?/FONT/SPAN/DIV
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2GiD 7.7.7b on win2000/FONT/SPAN/DIV
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2regards/FONT/SPAN/DIV
face=3DArial=20
color=3D#0000ff size=3D2mark/FONT/SPAN/DIVBR
DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr align=3Dleft
HR tabIndex=3D-1
FONT face=3DTahoma size=3D2BFrom:/B =
gidlist-admin at gid.cimne.upc.edu=20
[mailto:gidlist-admin at gid.cimne.upc.edu] BOn Behalf Of /BEnrique=20
EscolanoBRBSent:/B 04 February 2008 15:15BRBTo:/B=20
gidlist at gid.cimne.upc.eduBRBSubject:/B Re: [GiDlist] export =
deformed=20
meshBR/FONTBR/DIV
DIV/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2GiD 7.7.7b is a very =
old version for=20
this rjump feature. /FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2You must use one =
of the last=20
beta versions (8.1.x)/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2(can get a temporary =
password for the=20
8.x version)/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2/FONT /DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2Off course you can try =
to=20
manually merge surfaces, but it can require a lot of =
work./FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2Last beta vesions =
include also a new=20
command to merge surfaces with different algorithms (only from the =
boundary, or=20
using more iformation from the interior)/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2This command is under =
test,=20
and is only avaible at command line level (not from the =
menus)/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2escape geometry edit=20
joinsurfaces/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2Regards/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2Enrique/FONT/DIV
BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"
DIV style=3D"FONT: 10pt arial"----- Original Message ----- /DIV
DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"BFrom:/B=20
A title=3DMark.Smith at linx.co.uk =
href=3D"mailto:Mark.Smith at linx.co.uk"Smith,=20
Mark/A /DIV
title=3Dgidlist at gid.cimne.upc.edu=20
href=3D"mailto:gidlist at gid.cimne.upc.edu"gidlist at gid.cimne.upc.edu/A =
/DIV
DIV style=3D"FONT: 10pt arial"BSent:/B Monday, February 04, 2008 =
3:31=20
PM/DIV
DIV style=3D"FONT: 10pt arial"BSubject:/B RE: [GiDlist] export =
deformed=20
mesh/DIV
DIVBR/DIV
DIV dir=3Dltr align=3DleftSPAN class=3D715022314-04022008FONT =
face=3DArial=20
color=3D#0000ff size=3D2Hi Enrique/FONT/SPAN/DIV
face=3DArial=20
color=3D#0000ff size=3D2I have tried your suggestion without =
success. I get=20
the following error./FONT/SPAN/DIV
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2VoidPlex::set_at. Invalid void index=20
0/FONT/SPAN/DIV
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2Gid then crashes!/FONT/SPAN/DIV
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2I tried it on a simple rectangle where it =
worked fine.=20
What I would really like is for GiD to somehow merge/join surfaces =
together=20
creating larger areas of probably higher =
degree?/FONT/SPAN/DIV
face=3DArial=20
face=3DArial=20
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2win2000. GiD =
7.7.7b/FONT/SPAN/DIVBR
HR tabIndex=3D-1
EscolanoBRBSent:/B 04 February 2008 12:19BRBTo:/B=20
deformed=20
meshBR/FONTBR/DIV
DIV/DIV
DIVFONT face=3DArial size=3D2Have you tried to use the 'rjump' =
mesher=20
capabilities? (to create elements jumping between =
surfaces)/FONT/DIV
DIVFONT face=3DArial size=3D2You can select this mesher in the =
meshing=20
preferences, or you can manually set only some lines to be jumped or =
not=20
jumped/FONT/DIV
DIVFONT face=3DArial size=3D2Mesh->Mesh =
criteria->Skip/FONT/DIV
DIVFONT face=3DArial size=3D2/FONT /DIV
DIVFONT face=3DArial size=3D2Enrique/FONT/DIV
DIV----- Original Message ----- /DIV
DIV=20
black"BFrom:/B=20
Mark/A /DIV
/DIV
DIV style=3D"FONT: 10pt arial"BSent:/B Monday, February 04, =
2008 12:34=20
PM/DIV
deformed=20
mesh/DIV
DIVBR/DIV
DIV dir=3Dltr align=3DleftSPAN class=3D882161610-04022008FONT =
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2I need some advice on remeshing deformed=20
geometry./FONT/SPAN/DIV
face=3DArial=20
color=3D#0000ff size=3D2I have done an structural analysis using =
large=20
displacement (triangular) shell elements, I now want to create =
simplified=20
geometry from the deformed mesh data./FONT/SPAN/DIV
face=3DArial=20
color=3D#0000ff size=3D2I can use Enrique's method to produce new =
geometry of=20
the part with triangle surfaces. These triangles will on average =
have a=20
lower quality measure than the original undeformed mesh. I can see =
no way of=20
producing a simplified surface model from this highly faceted dxf =
import so=20
that I can mesh again with elements of a similar size but of better =
shape=20
quality. I can re-mesh with smaller elements but all the existing =
nodes are=20
that I=20
must manually delete surface & rebuild them =
again?/FONT/SPAN/DIV
face=3DArial=20
face=3DArial=20
DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr =
align=3Dleft
HR tabIndex=3D-1
[mailto:gidlist-admin at gid.cimne.upc.edu] BOn Behalf Of /BEnrique =
EscolanoBRBSent:/B 01 February 2008 12:50BRBTo:/B=20
deformed=20
meshBR/FONTBR/DIV
DIV/DIV
DIVFONT face=3DArial size=3D2Hello Jos=E9,/FONT/DIV
DIVFONT face=3DArial size=3D2It's not easy to remesh over a =
previous mesh=20
(e.g a mesh deformated while the analysis),/FONT/DIV
DIVFONT face=3DArial size=3D2You can import the GiD ASCII mesh =
of =20
triangles as a "Surface mesh" and try to remesh it/FONT/DIV
DIVFONT face=3DArial size=3D2or you can import each triangle as =
a surface=20
(with the trick explained exporting as dxf) and try to remesh this =
geometry=20
(can try to use rjump to avoid to have one or more new elements by=20
triangle). /FONT/DIV
DIVFONT face=3DArial size=3D2Whit the second approach do you =
have several=20
tools to edit the geometry to solve the problems (the =
surface-mesh=20
can't be handled with the classical geometrical tools)/FONT/DIV
DIV style=3D"FONT: 10pt arial"----- Original Message ----- =
/DIV
DIV=20
black"BFrom:/B=20
A title=3DJose.A.Fernandez at cedex.es=20
href=3D"mailto:Jose.A.Fernandez at cedex.es"Jose Antonio =
Fernandez/A /DIV
DIV style=3D"FONT: 10pt arial"BTo:/B A=20
href=3D"mailto:gidlist at gid.cimne.upc.edu"gidlist at gid.cimne.upc.edu/A=20
/DIV
DIV style=3D"FONT: 10pt arial"BSent:/B Friday, February 01, =
2008 10:33=20
AM/DIV
DIV style=3D"FONT: 10pt arial"BSubject:/B RE: [GiDlist] =
export=20
deformed mesh/DIV
DIVBR/DIV
DIV class=3DSection1
P class=3DMsoNormalFONT face=3DVerdana color=3Dblue =
size=3D2SPAN lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: =
Verdana"Hi,o:p/o:p/SPAN/FONT/P
style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Verdana"But, =
how can we=20
use results of an analysis in the pre-process? Is there any way to =
do=20
remeshing easily? (for localized failure or ALE algorithms for=20
instance)o:p/o:p/SPAN/FONT/P
Verdana"Thanks.o:p/o:p/SPAN/FONT/P
Verdana"Jos=E9o:p/o:p/SPAN/FONT/P
Verdana"o:p /o:p/SPAN/FONT/P
DIV
DIV class=3DMsoNormal style=3D"TEXT-ALIGN: center" =
align=3DcenterFONT=20
face=3D"Times New Roman" size=3D3SPAN style=3D"FONT-SIZE: 12pt"
HR tabIndex=3D-1 align=3Dcenter width=3D"100%" SIZE=3D2
/SPAN/FONT/DIV
P class=3DMsoNormalBFONT face=3DTahoma size=3D2SPAN=20
style=3D"FONT-WEIGHT: bold; FONT-SIZE: 10pt; FONT-FAMILY: =
Tahoma"De:/SPAN/FONT/BFONT=20
face=3DTahoma size=3D2SPAN style=3D"FONT-SIZE: 10pt; =
FONT-FAMILY: Tahoma" A=20
href=3D"mailto:gidlist-admin at gid.cimne.upc.edu"gidlist-admin at gid.cimne.u=
pc.edu/A=20
[mailto:gidlist-admin at gid.cimne.upc.edu] BSPAN=20
style=3D"FONT-WEIGHT: bold"En nombre de /SPAN/BEnrique=20
EscolanoBRBSPAN style=3D"FONT-WEIGHT: bold"Enviado =
el:/SPAN/B=20
jueves, 31 de enero de 2008 20:33BRBSPAN=20
style=3D"FONT-WEIGHT: bold"Para:/SPAN/B A=20
href=3D"mailto:gidlist at gid.cimne.upc.edu"gidlist at gid.cimne.upc.edu/AB=
RBSPAN=20
style=3D"FONT-WEIGHT: bold"Asunto:/SPAN/B Re: [GiDlist] =
export deformed=20
mesh/SPAN/FONTo:p/o:p/P/DIV
P class=3DMsoNormalFONT face=3D"Times New Roman" size=3D3SPAN =
style=3D"FONT-SIZE: 12pt"o:p /o:p/SPAN/FONT/P
DIV
P class=3DMsoNormalFONT face=3DArial size=3D2SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"Hi=20
Mark,/SPAN/FONTo:p/o:p/P/DIV
DIV
style=3D"FONT-SIZE: =
12pt" o:p/o:p/SPAN/FONT/P/DIV
DIV
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"You can export from=20
postprocess the deformated mesh (it's written in GiD mesh ASCII=20
format)/SPAN/FONTo:p/o:p/P/DIV
DIV
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"and you can read =
this mesh=20
with an external program to calculate the enclosed volume=20
DIV
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"(this volume =
calculation from=20
a boundary mesh is trivial )/SPAN/FONTo:p/o:p/P/DIV
DIV
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"Or you can do a =
macro to ask=20
GiD about the mesh and deformation result and calculate the volume =
with a=20
tcl procedure (but ask the mesh with Tcl can be slow for big=20
meshes)/SPAN/FONTo:p/o:p/P/DIV
DIV
DIV
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"If do you need to do =
this=20
calculation only once for this case, as trick, you can import the =
previous=20
GiD mesh file in preprocess again, then export again as dxf with =
the=20
DXFSap2000 template, and import again in GiD to convert each =
triangle in a=20
surface. Then create a volume with this surfaces and ask his=20
volume./SPAN/FONTo:p/o:p/P/DIV
DIV
DIV
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: =
Arial"Enrique/SPAN/FONTo:p/o:p/P/DIV
BLOCKQUOTE=20
style=3D"BORDER-RIGHT: medium none; PADDING-RIGHT: 0cm; =
BORDER-TOP: medium none; PADDING-LEFT: 4pt; PADDING-BOTTOM: 0cm; MARGIN: =
5pt 0cm 5pt 3.75pt; BORDER-LEFT: black 1.5pt solid; PADDING-TOP: 0cm; =
BORDER-BOTTOM: medium none"
DIV
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"----- Original =
Message -----=20
DIV style=3D"font-color: black"
P class=3DMsoNormal style=3D"BACKGROUND: #e4e4e4"BFONT =
face=3DArial=20
size=3D2SPAN=20
Arial"From:/SPAN/FONT/BFONT=20
face=3DArial size=3D2SPAN style=3D"FONT-SIZE: 10pt; =
FONT-FAMILY: Arial" A=20
Mark/A o:p/o:p/SPAN/FONT/P/DIV
DIV
P class=3DMsoNormalBFONT face=3DArial size=3D2SPAN=20
Arial"To:/SPAN/FONT/BFONT=20
DIV
Arial"Sent:/SPAN/FONT/BFONT=20
FONT-FAMILY: Arial"=20
Thursday, January 31, 2008 6:55 =
PMo:p/o:p/SPAN/FONT/P/DIV
DIV
Arial"Subject:/SPAN/FONT/BFONT=20
[GiDlist] export deformed =
mesho:p/o:p/SPAN/FONT/P/DIV
DIV
P class=3DMsoNormalFONT face=3D"Times New Roman" =
size=3D3SPAN=20
12pt"o:p /o:p/SPAN/FONT/P/DIV
DIV
P class=3DMsoNormalFONT face=3DArial color=3Dblue =
size=3D2SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial"Hi=20
Gidders/SPAN/FONTo:p/o:p/P/DIV
DIV
size=3D2SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial"I've =
been doing=20
some analysis of the deflections of a shelled container =
subject to=20
an external pressure. I can view the deformed structure in GiD =
but now=20
need to somehow make a measurement of the volume change. Is =
there anyway=20
I can export the deformed mesh as geometry so I can import it =
into gid=20
as geometry create a volume, then do =
utilities:list:volumes(mass)=20
? Or is there an even easier =
way?/SPAN/FONTo:p/o:p/P/DIV
DIV
size=3D2SPAN=20
Arial"regards/SPAN/FONTo:p/o:p/P/DIV
DIV
size=3D2SPAN=20
Arial"mark/SPAN/FONTo:p/o:p/P/DIV
PFONT face=3D"Times New Roman" size=3D3SPAN=20
style=3D"FONT-SIZE: 12pt"This message (including any =
attachments)=20
contains confidential BRand/or proprietary information =
intended only=20
for the addressee. BRAny unauthorized disclosure, copying,=20
distribution or reliance on BRthe contents of this information =
is=20
strictly prohibited and may BRconstitute a violation of law. =
If you=20
are not the intended BRrecipient, please notify the sender =
immediately=20
by responding to BRthis e-mail, and delete the message from =
your=20
system. If you BRhave any questions about this e-mail please =
notify=20
the sender=20
BRimmediately.o:p/o:p/SPAN/FONT/P/BLOCKQUOTE/DIV/BLOCKQU=
OTE
PThis message (including any attachments) contains confidential =
BRand/or=20
proprietary information intended only for the addressee. BRAny=20
unauthorized disclosure, copying, distribution or reliance on =
BRthe=20
contents of this information is strictly prohibited and may =
BRconstitute a=20
violation of law. If you are not the intended BRrecipient, please =
notify=20
the sender immediately by responding to BRthis e-mail, and delete =
the=20
message from your system. If you BRhave any questions about this =
e-mail=20
please notify the sender BRimmediately.BR/P/BLOCKQUOTE
BRand/or=20
proprietary information intended only for the addressee. BRAny =
unauthorized=20
disclosure, copying, distribution or reliance on BRthe contents of =
this=20
information is strictly prohibited and may BRconstitute a violation =
of law.=20
If you are not the intended BRrecipient, please notify the sender=20
immediately by responding to BRthis e-mail, and delete the message =
from your=20
system. If you BRhave any questions about this e-mail please notify =
the=20
sender BRimmediately.BR/P/BLOCKQUOTE/BODY/HTML
p
This message (including any attachments) contains confidential br
and/or proprietary information intended only for the addressee. br
Any unauthorized disclosure, copying, distribution or reliance on br
the contents of this information is strictly prohibited and may br
constitute a violation of law. If you are not the intended br
recipient, please notify the sender immediately by responding to br
this e-mail, and delete the message from your system. If you br
have any questions about this e-mail please notify the sender br
immediately.br
/p
------_=_NextPart_001_01C86C9C.CD516473--
