[Gid14] can't change layer name
kstn
Post by kstn »
Hi
Seem like it's not possible to change the name of the sub-layers to a name of upper level, for example
Layers ChangeName abc//xyz xyz mescape
This command does not work because GiD (14.0.3) automatically appends abc// to xyz and there are no changes. Any idea how is this possible and solution to fix?
Best
Re: [Gid14] can't change layer name
Rename
This is not a simple change of name of a layer: you don't have one layers, you have two layers:
abc (without parent)
and
xyz (with parent layer=abc, its fullpath name is abc//xyz)
then you must do two steps:
1-change the parent of xyz to none
2-delete the layer abc
'Layers ChangeParent abc//xyz ""
'Layers delete abc
escape
Instead of process commands it is also possible to use Tcl direct commands
GiD_Layers edit parent abc//xyz ""
GiD_Layers delete abc
These changes of layers are not directy reflected in the layers window, you can force its refresh with this tcl proc
GidUtils::UpdateWindow LAYER
EthanObrien1973
Contact:
Post by EthanObrien1973 »
Thank you so much for this question! I've had a very similar problem recently, thanks again!
