I have a 1980*1980*450 cm volume and I would like to mesh it with 20 node Hexahedron elements, having 17 elements in each of the 1980 cm sides and 9 elements in the 450 cm side. I would be grateful if you help me how to do this. I am attaching the file as well.
Best Regards,
Arash Farzam
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100719/01ac63c5/attachment.htm
Desc: Meshing-Required.cnd
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100719/01ac63c5/attachment.obj
Desc: Meshing-Required.prb
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100719/01ac63c5/attachment-0001.obj
Desc: Meshing-Required.geo
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100719/01ac63c5/attachment-0002.obj
[GiDlist] Hexahedron Meshing
You have tried to use semi-structured mesh. Must use structured mesh.
Mesh-Structured-Volumes-Assign number of cells
select the volume, and set number of divisions=17 in two lines of the base, and 9 in some line of the third direction.
To create quadratic hexahedra of 20 nodes go to
Utilities-Preferences - Meshing,
and set the variable 'Quadratic type' to 'Quadratic'
(Normal will generate linear 8-nodes hexa, Quadratic will generate quadratic serendipit 20-nodes hexa and Quadratic9 will generat quadratic lagrangian 27-nodes hexa)
and generate the mesh (the general size doesn't matter in this case, because all sizes are set by the number of structured divisions)
Sent: Monday, July 19, 2010 9:56 PM
Subject: [GiDlist] Hexahedron Meshing
Best Regards,
Arash Farzam
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100720/fef891f3/attachment.htm
Best Regards,
Arash Farzam
