It is possible to determine the accumulated values
BPA
Post by BPA »
Hi!
I wanted to know if i can have more values ​​at the end of the graph.
Since changing in interval data I can not have more points at the end of the graph so that its trend looks good.
Thanks.
Re: It is possible to determine the accumulated values
Sorry, I don't understand your question.
Which problemtype are you using?
Where and how is created/showed this graph?
It is the graph showing the 'table' values of a question field in preprocess, or it is a graph of some result in postprocess?
In the first case, can add a new row of the table pressing the 'down arrow' button that is showed clicking the entry field.
and can also use copy/paste (for example from Excel) to populate it.
