Gid ver 9.0.4
Hi Gid team
Is it possible to produce different mesh types in different regions? In
the attached simple test model I want to be able to produce a structured
mesh in the "dome" region and a tetrahedral mesh in the "cap" region,
both meshes can and will share the same nodes at the interface between
the 2 bodies so I think it should be possible but can't figure out a way
to do it ;-( Any Ideas?
mark
Please be advised that this email may contain confidential
information. If you are not the intended recipient, please notify us
by email by replying to the sender and delete this message. The
sender disclaims that the content of this email constitutes an offer
to enter into, or the acceptance of, any agreement; provided that the
foregoing does not invalidate the binding effect of any digital or
other electronic reproduction of a manual signature that is included
in any attachment.
Name: mixed mesh test.geo
Desc: mixed mesh test.geo
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100714/9dc55593/attachment.obj
[GiDlist] Mixed meshes
Is possible to do it, but the elements must be compatible: e.g. the
structured park instead of generate hexahedra must be set to generate
tetrahedra (because triangular faces are shared with the unstructured part
of tetrahedra)
To set the dome to be meshed as structured its volumes must have exactly 6
faces: I rebuilt again this part by revolution, to have this 6-faced
volumes.
I attach my model including the mesh (I set a number of 5 structured
divisions for all directions)
Sent: Wednesday, July 14, 2010 2:14 PM
Subject: [GiDlist] Mixed meshes
Gid ver 9.0.4
Hi Gid team
mark
in any attachment.
Name: mixed mesh test.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100714/addf7723/attachment.obj
of tetrahedra)
volumes.
Gid ver 9.0.4
Hi Gid team
mark
in any attachment.
