[GiDlist] NUST International Conference on Earthquake Engine
Engr. Dr. AQ Bhatti
Post by Engr. Dr. AQ Bhatti »
Hope that you are fine and best of your health. NUST would like to
organise international conference on earthquake engineering and seismology
in 25-26 April 2011. Please see the attached call for papers. Thanks and
looking forward for your positive input and participation.
Best regards and wishes
Dr. Abdul Qadir Bhatti
School of Civil and Environmental Engineering, SCEE, NUST, H-12, Islamabad,
Pakistan
Tel : 92-3022669974 and 92-51-90854615
E-mail : bhatti-nit at nust.edu.pk and icees2011 at gmail.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100628/6504aa83/attachment.htm
Type: application/pdf
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100628/6504aa83/attachment.pdf
deepak tunuguntla
[GiDlist] Knot insertion and degree elevation
Post by deepak tunuguntla »
I have always tried to send emails to the GiDlist at gid.cimne.upc.edu .
But unfortunately it never went.I dont know what's wrong though.
Anyway your help or suggestion shall be valuable for my work.
I have been going through the scripts in order to find the tcl code for
the GID_process InsertKnot and DegreeElevate so that it could help me modify the GID for
my own purpose.
I would like to actually connect my process to the GID library by creating macros , as a standard user interface.
My trials have always lead to nothing.
Hope your assistance shall help me.
Looking forward for your response
Deepak Tunuguntla
Institute of Structural Mechanics
University of Stuttgart, Germany
http://www.ibb.uni-stuttgart.de
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/da96f281/attachment.htm
dollarbulldog at hotmail.com
Post by dollarbulldog at hotmail.com »
TT
Sent via BlackBerry® from True Move
-----Original Message-----
Sender: gidlist-admin at gid.cimne.upc.edu
Date: Tue, 29 Jun 2010 11:49:26
To: GiDlist at gid.cimne.upc.edu
Reply-To: gidlist at gid.cimne.upc.edu
Subject: [GiDlist] Knot insertion and degree elevation
my own purpose.
Deepak Tunuguntla
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/04abdddf/attachment.htm
Now the GiD list is working again as you can see,
About your question, you must use something like this:
GiD_Process Mescape Geometry Edit EdNurbsLine $num DegreeElevate escape
set t 0.25
GiD_Process Mescape Geometry Edit EdNurbsLine $num InsertKnot $t escape
For future versions we can think to add an 'edit' subcommand to the GiD_Geometry tcl command, to allow a more direct entities modification.
Sent: Tuesday, June 29, 2010 11:49 AM
my own purpose.
Deepak Tunuguntla
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/d78cfd24/attachment.htm
deepak tunuguntla
hello,
is it possible to get the script ,like the TCL code for DegreeElevate and InsertKnot.
deepak
set t 0.25
my own purpose.
Deepak Tunuguntla
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/61f956ef/attachment.htm
Smith, Mark
[GiDlist] Gid 9.1.1b X64 on windows 7 professional
Post by Smith, Mark »
Hi Gid team
I've installed Gid 9.1.1b 64bit on windows 7 professional and there
seems to be a graphics bug. When I try to select geometry no bounding
box is shown making it difficult to know what items are selected, if I
open in safe mode all work OK but it runs very slowly.
My graphics card is NVIDIA GeForce GTS 250 , on trying to update the
driver windows tells me it is using the most up to date one?
Gid 9.3.1b x64 shows the same problem? Other than safe mode is there a
fix?
mark
Please be advised that this email may contain confidential
information. If you are not the intended recipient, please notify us
by email by replying to the sender and delete this message. The
sender disclaims that the content of this email constitutes an offer
to enter into, or the acceptance of, any agreement; provided that the
foregoing does not invalidate the binding effect of any digital or
other electronic reproduction of a manual signature that is included
in any attachment.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/feac5a40/attachment.htm
I don't understand this question.
Do you mean to have a tcl procedure that calculate at tcl scripting level the new control points, knots, etc after a degree elevation, etc?
This calculation is done internally at C++ level, faster than at tcl scripting level, and there are involved a lot of functions to do this maths (we are not going to replicate this NURBS funcions in pure tcl).
Sent: Tuesday, June 29, 2010 5:14 PM
Subject: Re: [GiDlist] Knot insertion and degree elevation
hello,
deepak
set t 0.25
my own purpose.
Deepak Tunuguntla
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/ce2bd9ee/attachment.htm
deepak tunuguntla
For example :
If i create a user defined process like DegreeElevation and i want to make an User Interface like the one we get by using the option 'Edit nurbs' in GID.
In the Edit Nurbs option the Elevate Degree automatically elevates the degree to 4.
I want to make an interface which takes the user input. like
Enter the Degree : --------
And then this calls the
process DegreeElevation{ degree}
I just wanted to know how i can incorporate in GID.
hello,
deepak
set t 0.25
my own purpose.
Deepak Tunuguntla
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/d4c1ca8e/attachment.htm
You can do it with the related Tcl command:
You must create your own window to collect the line number (picking on screen) and the required degree, and
use GiD_Info or GiD_Geometry Tcl commands to know the current degree of the selected line, and increase it until the required one calling several times if necessary the degree elevation process command.
Note: to select the entity you can use an auxiliary tcl procedure we defined inside dev_kit.tcl to aid scripting developers.
GidUtils::PickEntities { type selectmode }
e.g.
set num [GidUtils::PickEntities Lines single]
if { $num != "" } {
Sent: Tuesday, June 29, 2010 6:26 PM
For example :
hello,
deepak
set t 0.25
my own purpose.
Deepak Tunuguntla
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100629/29cccaf1/attachment.htm
Post by miguel »
yes, there is:
1. open the preferences window
2. select the 'Graphical panel'
3. inside the OpenGL group, check the 'Selection lines by software
(emulateFrontBuffer)
Miguel Pasenau
De: gidlist-admin at gid.cimne.upc.edu [mailto:gidlist-admin at gid.cimne.upc.edu]
En nombre de Smith, Mark
Enviado el: martes, 29 de junio de 2010 16:58
Asunto: [GiDlist] Gid 9.1.1b X64 on windows 7 professional
Hi Gid team
I've installed Gid 9.1.1b 64bit on windows 7 professional and there seems to
be a graphics bug. When I try to select geometry no bounding box is shown
making it difficult to know what items are selected, if I open in safe mode
My graphics card is NVIDIA GeForce GTS 250 , on trying to update the driver
Gid 9.3.1b x64 shows the same problem? Other than safe mode is there a fix?
mark
in any attachment.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100630/7aadb3ef/attachment.htm
Name: not available
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100630/7aadb3ef/attachment.png
