sección no prismática
carlosebernal
Post by carlosebernal »
hola a todos, estoy desarrollando un puente simplemente apoyado y me he encontrado con que las vigas cabezal cuenta con una sección no prismática, ¿Cómo puedo asignar esta sección?
Hello everyone, I am developing a bridge simply supported and I have found that the head beams have a non-prismatic section, how can I assign this section?
Re: sección no prismática
The answer to this question doesn't depends on GiD, depends on the problemtype.
If do you have a property (e.g. a section) that is not constant along a line, then maybe you can approximate it dividing the line and applying to each part a constant value
