question about “copy” command
BruceMan
Post by BruceMan »
Hi,I am a new user,and I have difficulty in "copy" command:
I want to creat many zerolength elements,I could not use "copy" command to creat points that have the same coordinate.
so,how to use "cpoy" command to get a lot of points or lines that have the same coordinate?
Furthermore,if I have MANY points need to use dof,how to batch operation?
THANK YOU VERY MUCH! :mrgreen:
Re: question about “copy” command
In the copy window, unset the 'Collapse' checkbutton
then new copies will be created, also if the new location is on the same location that other entities.
And with the 'Multiple copies' entry you can create several copies.
Note: new entities will be created on the same layer as the original entity, or in the current 'layer to use', depending on the 'Maintain layers' checkbutton.
BruceMan
Post by BruceMan »
escolano wrote:In the copy window, unset the 'Collapse' checkbutton
Thank you! I will try that.
