Hi GiD-Team,
i have one question concerning the GiDpost library.
Using harmonic or transient analysis there will appear no duplicate
result step values, but when using eigenFrequency analysis, it is well
known, that duplicate result values will occur.
Currently GiD complains when loading those result files, that there are
duplicate result values in the referring file. Is there any chance to
create a GiDpost file will contain the correct result values AND that
may be read by GiD?
Martin
SIMetris GmbH
Dipl.-Ing. Martin Meiler
Am Weichselgarten 7
D - 91058 Erlangen-Tennenlohe
Tel.: +49 (0)9131 691 280
Fax.: +49 (0)9131 691 285
Email: martin.meiler at simetris.de
Internet: www.simetris.de
Nächste Veranstaltungen:
SIMetris GmbH
Sitz der Gesellschaft Erlangen
Registered Office
Registergericht Amtsgericht Fürth, HRB 10659
Register Court
Ust-IdNr. DE249523369
VAT-IN
Geschäftsführer Dipl.-Ing. Martin Meiler
Executive Director
Wissenschaftlicher Beirat Prof. Dr.-Ing. Reinhard Lerch
Scientific Advisory Board Prof. Dr. techn. Manfred Kaltenbacher
Legal Disclaimer
This electronic message contains information that is confidential. The
information is intended for the use of the addressee only. If you are
not the addressee we would appreciate your notification in this respect.
Please note that any disclosure, copy, distribution or use of the
contents of this message is prohibited and may be unlawful. We have
taken every reasonable precaution to ensure that any kind of attachment
to this e-mail has been swept for viruses. However, we cannot accept
liability for any damage sustained as a result of software viruses and
would advise you to carry out your own virus checks before opening any
attachment.
Diese elektronische Nachricht ist vertraulich. Die Information ist nur
für den Adressaten bestimmt. Falls Sie nicht der Adressat sind, wären
wir Ihnen für eine entsprechende Information sehr dankbar. Bitte
beachten Sie, dass es in diesem Fall verboten und gesetzeswidrig ist,
diese Nachricht zu kopieren, weiterzuleiten oder zu benutzen. Es wurden
alle möglichen Massnahmen getroffen um eine Virusfreiheit der
beigefügten Dateien zu gewährleisten. Wir übernehmen jedoch keine
Verantwortung für Schäden, die aufgrund von Software Viren entstehen
und empfehlen Ihnen vor Benutzung der Dateien eine Überprüfung auf Viren
durchzuführen.
[GiDlist] gidpost library
I don't understand what is the problem with eigenFrequency analysis.
how are its results? why do you say that there are duplicated?
I think that you can assign to each result a different name or a different
'time step' not?
How are the result headers you want to write where duplications can't be
avoided?
Sent: Wednesday, March 03, 2010 5:19 PM
Subject: [GiDlist] gidpost library
Hi GiD-Team,
may be read by GiD?
Martin
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
GiDlist at gid.cimne.upc.edu
'time step' not?
avoided?
Hi GiD-Team,
may be read by GiD?
Martin
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
Let's clarify things:
This is the gidpost procedure we are calling:
int GiD_BeginResultHeader(GP_CONST char * Result,
GP_CONST char * Analysis,
double step,
GiD_ResultType Type, GiD_ResultLocation Where,
GP_CONST char * GaussPointsName);
That means that the following values might me assigned:
Result: "mechDisplacement"
Analysis: "eigenFrequency_1"
step: 1275.25
Now it is possible that two results of an eigenFrequency analysis have
the same eigenFrequency however not the same mode shape.
That means the resulting *.post.bin file will contain two results of
one analysis with the same step value.
This is what GiD complains about. The question is if there is a method
to avoid that.
I can also provide a sample post.bin file to make things clear.
Martin
different 'time step' not?
avoided?
----- Original Message ----- From: "Martin.Meiler"
Martin.Meiler at simetris.de
Hi GiD-Team,
may be read by GiD?
Martin
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
Mit freundlichen Grüßen
Martin Meiler
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
double step,
step: 1275.25
to avoid that.
Martin
avoided?
Hi GiD-Team,
may be read by GiD?
Martin
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
Martin Meiler
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
inside GiD the combination of Analysis+StepValue+ResultName should be unique, because GiD uses it to identify a result.
As you say, you have two results (with same name, analysis and step value), but from different 'mode shape'. Is that right?
If so, then you have two possibilities:
1. name a different analysis for each mode shape or
2. include the 'mode shape' as part of the result name, for instance:
Analisys: "whatever"
Step value: x.x
Result name: "ModeShape_1//ResultName_a" ( note the double '/', like the folder separator in unix)
Step value: x.x
Result name: "ModeShape_2//ResultName_a" ( note the double '/', like the folder separator in unix)
This way, when GiD display the result names, will group all results with the same 'prefix' (ModeSahpe_1) in the same branch of the tree or submenu.
You can group the result into as many subgroups as you want, for instance:
g1//b1//r1
g1//b1//r2
g1//b1//r3
g1//b2//r1
g1//b2//r2
g1//b2//r3
g2//b1//r1
g2//b1//r2
g2//b1//r3
GiD will group the results:
g1-+-b1-+-r1
| +-r2
| +-r3
+-b2-+-r1
+-r2
+-r3
g2---b1-+-r1
+-r2
+-r3
Miguel Pasenau
De: gidlist-admin at gatxan.cimne.upc.edu [mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Martin.Meiler
Enviado el: jueves, 04 de marzo de 2010 18:43
Asunto: Re: [GiDlist] gidpost library
double step,
step: 1275.25
to avoid that.
Martin
avoided?
Hi GiD-Team,
may be read by GiD?
Martin
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
Martin Meiler
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
Step value: x.x
Step value: x.x
g1//b1//r1
g1//b1//r2
g1//b1//r3
g1//b2//r1
g1//b2//r2
g1//b2//r3
g2//b1//r1
g2//b1//r2
g2//b1//r3
g1-+-b1-+-r1
| +-r2
| +-r3
+-b2-+-r1
+-r2
+-r3
g2---b1-+-r1
+-r2
+-r3
Miguel Pasenau
double step,
step: 1275.25
to avoid that.
Martin
avoided?
Hi GiD-Team,
may be read by GiD?
Martin
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
Martin Meiler
SIMetris GmbH
Am Weichselgarten 7
SIMetris GmbH
Registered Office
Register Court
VAT-IN
Executive Director
Legal Disclaimer
attachment.
durchzuführen.
