Hi
the first i'm convert one surface into in the GID software to volume ,after that I plan to convert two distinct six-node solid element that next to each other, while in the middle of these two distinct six-node solid element, there is one linear beam column element while I plan to convert two distinct six-node solid element into an eight-node element (Hexahedra element); I'd appreciate if you guided me step-by-step about this case.
thanks in advance.
The conversion of two distinct six-element elements of an eight Korean element
- 5.JPG (178.05 KiB) Viewed 4001 times
- 4.JPG (119.29 KiB) Viewed 4001 times
- 3.JPG (153.98 KiB) Viewed 4001 times
- 2.JPG (219.69 KiB) Viewed 4001 times
- 1.JPG (190.39 KiB) Viewed 4001 times
Re: The conversion of two distinct six-element elements of an eight Korean element
It is answered in the second part of your message...
