import .msh file crash gid program
jinsu421
Post by jinsu421 »
hello, i have about a 520000 nodes original instructure model. (it makes another file extension)
And when converting from this file to msh file maybe success,
but Importing Gid Mesh is crash gid program(suddenly shut down gid).
Deleting 4 Elements(Quad elements) was successful import.
But i do not want.
Let me know what's wrong.
If possible test this file and could you please keep me update of the proceedings?
thanks for your time.
ssississsi.7z
converted .msh file
(2.64 MiB) Downloaded 793 times
jinsu421
Re: import .msh file crash gid program
Post by jinsu421 »
jinsu421 wrote:hello, i have about a 520000 nodes original instructure model. (it makes another file extension)
But i do not want.
Gid Version:13.0.4 and OS: win10
jinsu421
Post by jinsu421 »
But i do not want.
here is another model using same code.
And Deleteing 8 Elements (hexa elements) also occured same probelm.
jinsu421
Post by jinsu421 »
But i do not want.
ee09.7z
(391.36 KiB) Downloaded 884 times
The attached file 'ssississsi.msh' has wrong content (to be a valid 'GiD mesh ASCII'),
after some apparently right meshes has unexpected text like this: (text line 1.051.360)
==========================GiD KIESSI DATA V0.1====================================
$i10$STRUCTURE SOIL STRUCTURE MODEL
0 2.5000000E+01
*origin
and the same for the attached file 'e09_304.msh that has some extra text (that looks like NASTRAN input format)
$i10$P3/PATRAN Neutral File from: D:\SSSI_report\ 10\problem08_smart\kiessi
0 0.0000000E+00
*ORIGIN
0.0000000d0 0.0000000d0 0.0000000d0
*MATERIAL 12
1 1 1.5000000E+02 3.4700000E-01 1.6400000E+00 5.0000001E-02
jinsu421
Post by jinsu421 »
escolano wrote:The attached file 'ssississsi.msh' has wrong content (to be a valid 'GiD mesh ASCII'),
0 2.5000000E+01
*origin
0 0.0000000E+00
*ORIGIN
*MATERIAL 12
We need these extra data in our Problemtypes(plugin) for post processing and calculating.
What should i do ?
When you think of it simply, make another data file about these extra data and read.
Please tell me if you have a better idea.
Thanks.
A GiD mesh ASCII file must contain only what it is expected:
https://www.gidhome.com/documents/refer ... GiD%20mesh
otherwise is not a 'GiD mesh ASCII file' and GiD won't we able to import it (and must crash trying to read it)
If do you need other extra data, you can write it in other file, but this file will be in your own 'calculation format' and off course cannot be imported by GiD.
If do you want to import the 'mesh part' of your 'input calculation files' you can write two files, one with the mesh as 'GiD mesh ASCII file' (that can be re-imported if necessary by GiD), and other file that could have line to 'include the mesh file' and the rest of the calculation input file.
