Possible to source tcl file with arguments
awa5114
Post by awa5114 »
I would like to run GiD from the command line and have a tcl script act on it as follows:
gid -n -t tcl_script_path
Unfortunately my script also needs 2 command line arguments. So I tried this
gid -n -t "tcl_script_path arg1 arg2"
Which didn't work. Then I tried to source it from within GiD session as follows:
-np- source {tcl_script_path arg1 arg2}
But I got the following error Error: couldn't read file ....
How do I run a tcl script on GiD using command line arguments from the cmd command line (black screen)? Thanks...
Re: Possible to source tcl file with arguments
Is not valid, because the Tcl 'source' standard command expects only an argument, the Tcl filename to be sourced.
Its syntax is
source $filename
and about the GiD command line
gid -t tcl_script_path
is not valid because this syntax expects a tcl command, not a filename to be sourced
if the command already cannot be used, because it is not defined, you must before define sourcing it
e.g.
gid -t "source <your_filename> ; <your_procedure> <argument_1> ... <argument_n>"
or you can invoke your procedure directly inside your filename sourced.
