[GiDlist] Compatibility problems with Windows 7
almeidae at usp.br
Post by almeidae at usp.br »
Dear GiD users,
I'm having a lot of trouble with GiD 9.0.4 (GiD9.0.4-win-x64) in
Windows 7 professional and found it strange that nobody has complained
about it yet. The problem is that GiD freezes and does not respond after
some commands, for instance when I try to save a snapshot in
postprocessing mode.
Has someone observed something similar? Is there a compatibility
problem between the Windows Vista version of GiD and Windows 7?
Edgard.
Are you able to repeat the problem in a systematic way?
Could you explain us the exact commands used to 'freeze' GiD?
I think that it won't be a problem related to Windows 7,
You can also try the last 9.2.7b beta version:
http://www.gidhome.com/download/do07.html
The password of GiD 9.0.4 is valid for all 9.x versions
Sent: Sunday, January 31, 2010 1:59 PM
Subject: [GiDlist] Compatibility problems with Windows 7
Dear GiD users,
Edgard.
GiDlist at gid.cimne.upc.edu
almeidae at usp.br
Dear Enrique,
Sorry for the delay. It's not easy to reproduce my problem in Windows 7.
I'm working now with a very simple model and GiD v9.0.4 freezes when
I try to find the distance between two points. It asks for the two
points, then the label place, and it freezes processing
the command. The problem repeated three times. I'll restart my computer
to check if the problem persists. If not, I'll write again.
Edgard.
Citando Enrique Escolano escolano at cimne.upc.edu:
----- Original Message ----- From: almeidae at usp.br
Dear GiD users,
Edgard.
I tried to do the same, also with GiD 9.0.4 x32, but GiD is not frozing on
my Windows 7 tests.
maybe we are doing somethin slightly differernt.
I'm using the preprocess menu Utilities-Distance
and clicking some geometric points (and some new coordinated swapping to
NoJoin mode)
Sent: Wednesday, February 17, 2010 6:05 PM
Subject: Re: [GiDlist] Compatibility problems with Windows 7
Dear Enrique,
Edgard.
Dear GiD users,
after
Edgard.
almeidae at usp.br
Hi Enrique,
The problem I described is in the toolbox command `dimension distance
between two points', it still freezes GiD program in my computer, in
both 32 and 64-bits versions of GiD running Windows 7.
I tried to use the distance command in the menu and it works.
Edgard.
on my Windows 7 tests.
to NoJoin mode)
Dear Enrique,
Edgard.
Dear GiD users,
Edgard.
