Hello:
Can you please help with following questions:
1. What is algorithm used for Smooth Contour Fill?
2. What are equations used for calculating Si, Sii, Siii from 6 components
of Matrix type in post-processing?
Thank you in advance.
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100120/07c6582c/attachment.htm
[GiDlist] Algorithm used in Smooth Contour Fill
explained in GiD's help and in :
http://www.gidhome.com/support_team/gidbeta/gid125.html#POSTPROCESS%20RESULT
S%3ESmooth%20Contour%20Fill
http://www.gidhome.com/support_team/gidbeta/gid148.html#POSTPROCESS%20DATA%2
0FILES%3EPostprocess%20results%20format:%20ProjectName.post.res%3EResult%20b
lock
1.- foreach element incident to a node, the gauss point results are
extrapolated to the nodes. Then from the set of extrapolated values for that
node,
GiD uses:
- the minimum value if 'Options--Contour--Smoothing type--minimum value'
is selected;
- the maximum value if 'Options--Contour--Smoothing type--maximum value'
is selected;
- the mean value if 'Options--Contour--Smoothing type--mean value' is
selected ( == sum(all values) / NumValues)
2.- When a stress matrix is read, GiD calculates the eigen vectors and eigen
values of this matrix, then sort them according to the eigen values, being
Si the biggest value and Siii the smallest one.
Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Thanh Chau Dinh
Enviado el: miércoles, 20 de enero de 2010 16:59
Asunto: [GiDlist] Algorithm used in Smooth Contour Fill
Hello:
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100125/92180ef8/attachment.htm
lock
node,
GiD uses:
is selected;
is selected;
Miguel Pasenau
IMPORTANT NOTICE
Hello:
Thanh
2- Eigenvalues/eigenvector are calculated with an iterative Jacobi method
(see "Numerical Recipes in C" at http://www.nrbook.com/a/bookcpdf.php , chapter 11.1)
Sent: Monday, January 25, 2010 4:05 PM
Subject: RE: [GiDlist] Algorithm used in Smooth Contour Fill
http://www.gidhome.com/support_team/gidbeta/gid125.html#POSTPROCESS%20RESULTS%3ESmooth%20Contour%20Fill
http://www.gidhome.com/support_team/gidbeta/gid148.html#POSTPROCESS%20DATA%20FILES%3EPostprocess%20results%20format:%20ProjectName.post.res%3EResult%20block
1.- foreach element incident to a node, the gauss point results are extrapolated to the nodes. Then from the set of extrapolated values for that node,
GiD uses:
- the minimum value if 'Options--Contour--Smoothing type--minimum value' is selected;
- the maximum value if 'Options--Contour--Smoothing type--maximum value' is selected;
- the mean value if 'Options--Contour--Smoothing type--mean value' is selected ( == sum(all values) / NumValues)
2.- When a stress matrix is read, GiD calculates the eigen vectors and eigen values of this matrix, then sort them according to the eigen values, being Si the biggest value and Siii the smallest one.
Miguel Pasenau
IMPORTANT NOTICE
De: gidlist-admin at gatxan.cimne.upc.edu [mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Thanh Chau Dinh
Hello:
2. What are equations used for calculating Si, Sii, Siii from 6 components of Matrix type in post-processing?
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100125/8efac39f/attachment.htm
GiD uses:
Miguel Pasenau
IMPORTANT NOTICE
Hello:
Thanh
Hello:
Thanks for your clear reply.
Thanh
On Tue, Jan 26, 2010 at 12:05 AM, Miguel Adolfo Pasenau de Riera
node,
GiD uses:
is selected;
is selected;
Miguel Pasenau
IMPORTANT NOTICE
*De:* gidlist-admin at gatxan.cimne.upc.edu [mailto:
gidlist-admin at gatxan.cimne.upc.edu] *En nombre de *Thanh Chau Dinh
*Enviado el:* miércoles, 20 de enero de 2010 16:59
*Para:* gidlist at gatxan.cimne.upc.edu
*Asunto:* [GiDlist] Algorithm used in Smooth Contour Fill
Hello:
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100126/397394f2/attachment.htm
Thanh
node,
GiD uses:
is selected;
is selected;
Miguel Pasenau
IMPORTANT NOTICE
Hello:
Thanh
