Gid 10 & 11 does not start on ubuntu 18.04
kstn
Post by kstn »
Hello
When I start gid11 there is no error message and gid does not start. Starting gid 10 gives the following error message:
libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 887
Current serial number in output stream: 892
The system is Ubuntu 18.04 x64
kstn
Re: Gid 10 & 11 does not start on ubuntu 18.04
Post by kstn »
small update: after removing .gidDefaults, only gid 11 is not working
Post by miguel »
Hi kstn,
It seems that there is a problem with your graphics driver.
Try using 'gidx' instead of 'gid'. gidx will start gid in safe mode, i.e. using software rendering.
If GiD is installed in
$HOME/gid11.1.8d
, then just launch
$HOME/gid11.1.8d/gidx
Best and Thanks,
Miguel Pasenau
kstn
Post by kstn »
Hi Miguel
It also doesn't work.
Giang
Post by miguel »
Hi kstn,
this is very strange.
Can you please, open a terminal and execute
./gid -noredirect
./gidx -noredirect
and tell us what are the messages?
if nothing appears then do:
rm -rf /tmp/gid*
./gid
./gidx
cat /tmp/gid*/*
(GiD redirects stdout and stderror to temporary files)
you're using gid 11.1.8d x64 on your ubuntu 18.04, right?
thanks,
kstn
Post by kstn »
Hi Miguel
It also doesn't work. Below is the error log message. Sorry, can't attach the text file.
Giang
https://www.dropbox.com/s/n470xtbgzmk91 ... r.pdf?dl=0
about attachments in this forum, is possible to attach what you want as a .zip (with limited size)
