[GiDlist] vertical exageration in GiD
María del Mar García Alcaraz
Post by María del Mar García Alcaraz »
Hi everybody!
could someone help me to exagerate the z-axis, just the visualization. I
haven't found any command to do that.
Thanks in advance! Mar
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20111130/fefb72eb/attachment.htm
You can scale the model or mesh with the 'Move' window. with a scale transformation with scale parameters=1.0 in x, y and 1.0 in z
It is not just visualization, it really modify the node coordinates, but you can avoid to save the model after this change.
Sent: Wednesday, November 30, 2011 7:15 PM
Subject: [GiDlist] vertical exageration in GiD
Hi everybody!
could someone help me to exagerate the z-axis, just the visualization. I haven't found any command to do that.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20111130/477d80ee/attachment.htm
mgeetha at aol.com
[GiDlist] variable mesh sizes
Post by mgeetha at aol.com »
I have two regions assigned with different elastic properties.
I want to mesh (quadrilateral) with different mesh sizes for the two regions (depending on wavelengths for different regions).
Can anyone help me and explain how I can do it?
Thanks!
Vijayendra
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20111202/5b9dd5fc/attachment.htm
You must simply apply mesh sizes to geometric entities (lines, surfaces,...) Mesh-Unstructured-Assign size on ...
and generate a unstructured mesh of quads
must set also to geometric surfaces that you want this kind of element, else you will obtain triangles. (Mesh-Element type-Quadrilateral, and select the surfaces)
You can also generate structured meshes of quadrilaterals, but then the number of divisions is propagated
between neighbor surfaces, you only can concentrate elements in some part of the lines, but maintaning the number of divisions.
Sent: Friday, December 02, 2011 11:34 AM
Subject: [GiDlist] variable mesh sizes
Thanks!
Vijayendra
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20111213/2b89ab68/attachment.htm
