[GiDlist] If (strcmp) statement
Farzam, Arash
Post by Farzam, Arash »
Dear All,
I have written part of my .prb file (lines 10 and 11) as below:
QUESTION: Climate_Pattern_(NPATT):#CB#(Sinusoidal_Climate_Change,Constant_Climate_Change)
VALUE: Sinusoidal_Climate_Change
and I have an if statement in my .bas file as
*If(strcmp(Gendata(10),"Sinusoidal_Climate_Change")==0)
1 *\
*elseif(strcmp(Gendata(10),"Constant_Climate_Change")==0)
0 *\
*endif
But I don't get a value of 0 or 1 in the results file (whether I choose the first or second option).
Do you have an idea of what I am doing wrong?
Best Regards,
Arash Farzam
I have tested this (with GiD 10.1.6d win x32) and it worked well.
I think that probably the question Climate_Pattern_(NPATT):#CB#(Sinusoidal_Climate_Change,Constant_Climate_Change) is not the 10th question of your PROBLEM DATA block !!
note that questions are numbered from 1 to n, and is not the line number, is the question counter
to debug it you can also print the value of *Gendata(10)
GENDATA(10)=*Gendata(10)
1 *\
0 *\
*endif
To avoid index mistakes, and have a more easy to maintain (when adding/removing fields in future problemtype versions)
it is recommended to use the field name instead of the index
Gendata(1)=*GenData(Climate_Pattern_(NPATT))
*If(strcmp(Gendata(Climate_Pattern_(NPATT)),"Sinusoidal_Climate_Change")==0)
1 *\
*elseif(strcmp(Gendata(Climate_Pattern_(NPATT)),"Constant_Climate_Change")==0)
0 *\
*endif
Really the internal full name of the question is
"Climate_Pattern_(NPATT):#CB#(Sinusoidal_Climate_Change,Constant_Climate_Change) "
but to avoid so long and difficult names of this special fields is accepted the abbreviation removing from #CB# to the end
To: GiDlist at listas.cimne.upc.edu
Sent: Tuesday, June 14, 2011 7:55 AM
Subject: [GiDlist] If (strcmp) statement
Dear All,
1 *\
0 *\
*endif
Best Regards,
Arash Farzam
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110614/a506988c/attachment.htm
Jose Munoz
[GiDlist] Remote Desktop connection
Post by Jose Munoz »
Dear GID team,
When I access my Desktop via Remote Desktop application (in either
Windows or Mac), the GID program running on the remote computer crashes
(message says "runtime error").
I believe that when accessing via Remote Desktop the graphics mode (at
least the number of colours) is different from the mode I have when
directly visualising my GID program (not remotely). However, all other
programs that I am running on my remote machine manage to change the
mode. Is there anything I can do to avoid the crash of GID?
Many thanks,
Jose
Jose J Munoz, http://www-lacan.upc.es/munoz/
Laboratori de Càlcul Numèric (LaCàN)
Dep. Matemàtica Aplicada III
C/ Comte d'Urgell, 187, Room 1D010
Campus Urgell UPC, Edifici EUETIB
E-08036 Barcelona, Spain
j.munoz at upc.edu, Skype: josej.munoz, Tel. + 34 93 413 7253
We don't know what the 'Remote Desktop' exactly do. This is a program to
remotelly manage a Windows PC from a Mac, not?
Probably is some graphic problem as you pointed, try to start GiD without
any graphical acceleration
Go to Utilities-Preferences - Graphical, and select 'Safe visualization
mode' and press Accept (is is necessary restart GiD to apply it)
Note: off course redraws will be slower with this preference that use OpenGL
by software.
Sent: Wednesday, July 13, 2011 2:24 PM
Subject: [GiDlist] Remote Desktop connection
Dear GID team,
Many thanks,
Jose
Jose Munoz
Hi Enrique,
As far as I have tried, 'Remote Desktop' allows you to contact a PC from
a Mac or PC machine.
I have changed the visualisation mode, but I had no success. If you ever
find out the source of the problem, please let me know.
Many thanks,
Jose
by software.
To:gidlist at listas.cimne.upc.edu
Dear GID team,
Many thanks,
Jose
I am usually using the 'Remote Desktop Connection' standard tool of Windows
to open another Windows machine, and GiD works without any problem,
but I never user 'Remote Desktop' of Mac OS X to connect between Mac and
Windows.
Sent: Thursday, July 14, 2011 11:49 PM
Subject: Re: [GiDlist] Remote Desktop connection
Hi Enrique,
Many thanks,
Jose
OpenGL
by software.
Dear GID team,
Many thanks,
Jose
