[GiDlist] Postprocess: Integrate in All Steps
dpozo at cimne.upc.edu
Post by dpozo at cimne.upc.edu »
Hello GID team,
I have a problem using GID v 10.1.1d
POSTPROCESS
I
want to integrate the velocity (Vz) of a flow in a cross-section of a 3D
problem.
And to obtain the graph in all time steps.
The commands
sequence followed is:
Open the multiple files
Do cuts / cut
plane / 2 points / which meshes should be cut? All steps
I desactive
the other layers
VIEW RESULTS / INTEGRATE / ALL STEPS / SCALAR
RESULTS / VELOCITY / VZ
I select the cutted area to integrate
GID automatically Breaks down
I can do it in One Step and it shows me
the value.
I'm sure that is possible to do in all steps, because i did it
before many times. What's happening?
Could you help me?
Greetings from
Madrid.
Thank you very much.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110111/a0a51cd9/attachment.htm
Please, could you send us the example to have a look to the results?
(send it directly to escolano at cimne.upc.edu instead the GiD List)
Sent: Tuesday, January 11, 2011 10:00 AM
Subject: [GiDlist] Postprocess: Integrate in All Steps
!-- @page { margin: 2cm } P { margin-bottom: 0.21cm } --
Hello GID team,
POSTPROCESS
I want to integrate the velocity (Vz) of a flow in a cross-section of a 3D problem.
The commands sequence followed is:
1.. Open the multiple files
2.. Do cuts / cut plane / 2 points / which meshes should be cut? All steps
3.. I desactive the other layers
4.. View results / Integrate / All steps / Scalar results / velocity / Vz
5.. I select the cutted area to integrate
6.. GID automatically Breaks down
I can do it in One Step and it shows me the value.
I'm sure that is possible to do in all steps, because i did it before many times. What's happening?
Could you help me?
Greetings from Madrid.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20110111/eb46c0cd/attachment.htm
