Cannot add a line in GiD
awa5114
Post by awa5114 »
When trying to connect pre-existing points with a line in GiD I get the following error message:
"Entering points in screen is forbidden when plane (z=0) is orthogonal in current view"
It is true that the plane is orthogonal but this is how I want to enter my geometry. What is causing this error and how can I fix it?
Re: Cannot add a line in GiD
To connect existing points you must be in 'Join' mode (GiD expects a point integer id), not in 'No Join' mode (GiD expects three real coordinates)
While selecting you can swap this mode with the contextual menu 'Join/No Join' or easily with the <Ctrl-a> accelerator key
