[GiDlist] Force mesh
Eric Legrand
Post by Eric Legrand »
Hello
How can I force mesh of lines contains materials with tcl fonctions ?
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120413/ffd1df9f/attachment.htm
It is recommended to apply materials and conditions to the geometry and inherit them automatically when meshing.
You can assign materials to geometry or mesh elements from Tcl with the GiD_AssignData command (see help on GiD Customization - TCL-TK extension - Special funcions)
GiD_AssignData material|condition name over ?values? entities
To assign materials or conditions over entities:
name is the name of the material or condition;
over must be: points, lines, surfaces, volumes, layers, nodes, elements, body_elements, or face_elements (elements is equivalent to body_elements);
newvalues is only required for conditions. If it is set to "" then the default values are used;
entities a list of entities (it is valid to use ranges as a:b ,can use "all" to select everything, "end" to specify the last entity, layer:layername to select the entities in this layer) ; if over is face_elements then you must specify a list of "entitynumface" instead just "entity".
Also it is possible to use the GiD_Process tcl command to do it, sending the appropiated GiD commands (the same you do as user level, or from a batch file)
An easy way to know this commands is do the action as user (assing the material to elements) and open the "Undo" windows that show the GiD keywords.
Sent: Friday, April 13, 2012 2:02 PM
Subject: [GiDlist] Force mesh
Hello
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120413/6255a51e/attachment.htm
Ramon Ribó
Post by Ramon Ribó »
CompassLIB has tools to mark some groups as they need to be meshed.
All the entities contained into them will be forced to be meshes
without the user required to do anything. Typically, these
groups have been assigned by the user to some kind of beam properties
or something similar.
http://www.compassis.com/compass/en/Productos/CompassLIB
[url=http://www.compassis.com%C2%A0]http://www.compassis.com[/url] ramsan at compassis.com
2012/4/13 Eric Legrand eric.legrand at cybernet.be:
Hello
