EOF too early
Kevin
EOF too early
Post by Kevin »
Hi there,
I am using code bright for my research on THM process in soil pile interaction but I am getting some errors while using external load on THM coupling. I am facing the problem of 'EOF in line 1', could you please help me to get solution of this problem.
Thank you
Re: EOF too early
This question must be asked inside the code_brigth subforum,
GiD show an error because the solver is not able to write any result.
