More than one boundary condtion that varies with time?
Moderator: CODE_BRIGHT Team
tonireg
Post by tonireg »
Is it possible to assign more than one boundary condition that varies with time?
For instance, assigning two different variable conditions to two different lines or surfaces?
Re: More than one boundary condtion that varies with time?
I think that Code_bright uses 'Data->Interval' to handle conditions to represent a 'constructive process' thas changes along the time.
Each 'GiD interval data' store a different collection of boundary conditions and interval data.
tonireg
Post by tonireg »
Thank you very much for your reply.
By "conditions that vary with time" I meant conditions you enter in a <project_name>_bcf.dat file.
I have to enter several temperature data in a dam configuration.
code_bright
Location: Universitat Politècnica de Catalunya, Barcelona
Contact:
Post by code_bright »
Yes, it is possible in the last version. You can find information about that both in the manual and the tutorials.
Alfonso
