Bad integer format
kstn
Bad integer format
Post by kstn »
Hello
I encounter a problem when writing all the nodes belong to a condition
the code in bas file:
Code: Select all
*set cond Surface_Group_Membership *nodes *canRepeat
*loop nodes *OnlyInCond
    node_groups['*cond(Group_Name)'].append( *NodesNum )
*end nodes
Executing this gives an error: Error in basefile ... at line number 154: Bad Integer format
However, if the bas file is modified a bit, this error goes away
Code: Select all
    *cond(Group_Name) is touched
*end nodes
Of course, this is not what I want
Is it a bug, or something wrong anyway?
Re: Bad integer format
I have tried it with Gid 12.1.10d Windows x32 and in my test worked well.
I have used this problemtype:
kstn.zip
(1.35 KiB) Downloaded 506 times
and this small example:
test_kstn.zip
(4.25 KiB) Downloaded 492 times
and the result was ok: (the file test_kstn.dat of the example)
If your problem persist with an updated version of GiD attach your problemtype and model.
kstn
Post by kstn »
The problem still persists. In the attached file you can find the files to reproduce the problem.
kstn.gid.tar.gz
(691 Bytes) Downloaded 756 times
cube.gid.tar.gz
(11.33 KiB) Downloaded 816 times
