output in postprocess
gchen
Post by gchen »
Dear Friends
In Gid 12.0 postprocess, when I use "several graphs" to output the results of several points versus time, then "Export"->"graph", if I open the output file in excel, the data are stored in two columns with the results at different points locating one after the other. In most cases, I would like the data opened in excel file has the format like "first column: time; 2nd column: results of the 1st point; 3rd column: results of the 2nd point, and so on".
Does someboday have good experience with the data arrangement?
Thanks in advance!
gchen
Re: output in postprocess
Files->Export->Graph (or contextual menu Export->Graph) as you said write the graphs data in a simple text format (gnu-plot like in the past) that could be easily read also by Microsoft Excel (using spaces as separator).
Each graph is written as a x-y two columns.
In general it is not possible to write all graphs of the same 'graph set' as multiple-columns as you suggest.
x y1 y2 ... yn
because x are not shared (equal) for all graphs. Only in some particular case like plot a collection of points along the time steps the x is the same for all graphs (because all have the same time steps)
I think that you must manually edit in Excel the data to have the multi-columns you want (to facilitate create the graphs in Excel).
Off course it is possible (and easy) to write a user-macro in Tcl language to export graph data with the syntax you want in a text file.
Code: Select all
GiD_Graph list
return a list of the graphs (of the current graphset in use)
and
Code: Select all
GiD_Graph get <graph_name>
return its titles and x-y data
Another comment: in the 'options' tab of the graphs window you can select a graph and press the 'Show table' button.
Then a table will show the graph values. You can modify its values and also use copy/paste to transfer the selected values to Excel (without export them to an auxiliary file).
Clicking the headers of the table the whole columns will be selected.
gchen
Post by gchen »
Dear Escolano
Thanks a lot for your useful information!
Kind regards
gchen
