Visualizing OpenFOAM VTK files in GiD
Hosam
Post by Hosam »
We have VTK results generated by OpenFOAM and want to use GiD for post-processing. Is this possible?
Thanks!
Hosam
Re: Visualizing OpenFOAM VTK files in GiD
Go to postprocess and use Files->Import->Vtk...
Hosam
Post by Hosam »
Thanks!
Hosam
Post by Hosam »
escolano wrote:Go to postprocess and use Files->Import->Vtk...
It worked for only one vtk file at a time. Is it possible to visualize a series of VTK files (each one corresponding to a time step), for example:
sim_0.vtk
sim_1.vtk
sim_2.vtk
sim_3.vtk
sim_4.vtk
sim_5.vtk
sim_6.vtk
sim_7.vtk
sim_8.vtk
sim_9.vtk
to generate an animation for example, or a graph over time?
Hosam
the dialog window of Files->Import->Vtk... allow the selection of multiple files,
select all vtk files: sim_XX.vtk
The time step will be obtained from XX (Vtk unfortunatelly doesn't support the concept of time step, and this value is codified as a trick in the filenames)
Then you will have in GiD a results along the time and you could do animations, show graphs along the time, etc.
Hosam
Post by Hosam »
It worked. Thanks!
