Structured meshing by size in Tcl
eduardrocas
Post by eduardrocas »
I'm using Tcl to mesh a geometry. I would like to know which is the command to implement the following:
Mesh --> Structured --> Surfaces --> Assign size ...
The command "GiD_Process Mescape Meshing Structured Surfaces..." implements only the meshing by number of cells, by default.
Eduard
amelendo
Re: Structured meshing by size in Tcl
Post by amelendo »
The Command you are searching is:
"GiD_Process Mescape Meshing Structured Surfaces Size ..."
In general, to know what is the internal process commands you can do the action as user, and then open the Undo window <Ctrl>-z to read the keywords used.
eduardrocas
Thanks!
taherghazvini
Post by taherghazvini »
Hi
how can i generate regular meshing when i have curve and rectangular surfaces together?
please help me!
abelcs
Post by abelcs »
what do you mean with 'regular' meshing?
