[GiDlist] Sequential Node Numbering
sujith gowda
Post by sujith gowda »
I would like to know about some proper sequencing of node numbering in GID,
I tried with the options available as ReNumbermethod -2,-1,0,1,2..
Every method gives me some random kind of numbering, is there any
possibility to have a sequential numbering ( row wise or column wise ).
For example,
Gid gives me as in attached (gid.jpg) and I require as shown in req.jpg.
Kindly let me know the possible solution.
Thank you,
*Sujith Gowda H S*
Universität Stuttgart,
Germany
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140930/e142aefe/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140930/e142aefe/attachment-0001.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140930/e142aefe/attachment-0001.jpeg
This is the GiD help about the renumbermethod value meaning
In mesh mode, the renumbered entities are the mesh ones. In this case, renumbering not only fills the gaps in the labels list but also changes the node numbers so as to minimize the difference in node numbers within each element. This can be useful when the calculating module uses band or skyline storage methods.
The nodes renumeration algorithm can be set with the variable 'RenumberMethod' (see http://www.gidhome.com/component/manual/referencemanual/general_aspects/utilities_menu/preferences Preferences)
Accepted values are:
-2 : Avoid nodes and elements renumeration, entities numbers are set increasingly when they are generated.
-1 : Avoid nodes renumeration, nodes numbers are set increasingly when they are generated
0 : Geometrical algorimth, ordered by the distance to some coordinate. It is the default value
1 : Reverse Cuthill-McKee algorimth, similar to the previous one, but following element's connectivities
2 : ordered following the XYZ axes, interesting for special cases with geometry aligned to the axes
Then, the only method that could provide a kind of numeration ‘similar’ to what do you want, with structured meshes aligned to axis, is the RenumberMethod=2
Set this variable value for example writing this in the lower command line
mescape utilities variables renumbermethod 2 escape
This is the numeration that I have obtained for a rectangle aligned to axis with structured quadrilaterals, exactly what you asked for.
But this ordering is only based on xyz nodes coordinates, without take into account element connectivities, then numerical precision
could provide sometimes a wrong numeration for you.
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de sujith gowda
Enviado el: martes, 30 de septiembre de 2014 17:33
Asunto: [GiDlist] Sequential Node Numbering
Every method gives me some random kind of numbering, is there any possibility to have a sequential numbering ( row wise or column wise ).
For example,
Thank you,
Sujith Gowda H S
Germany
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140930/7f40a5bb/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140930/7f40a5bb/attachment.jpeg
sujith gowda
Thank you for the Information and solution form my problem.
*Sujith Gowda H S*
First Year M.Sc in COMMAS,
Germany
Phone: +49-17672126512
e-mail : sujit18.11 at gmail.com
On 30 September 2014 19:34, Enrique Escolano escolano at cimne.upc.edu wrote:
In *mesh* mode, the renumbered entities are the mesh ones. In this case,
'RenumberMethod' (see Preferences
they are generated
RenumberMethod=2
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *sujith gowda
*Enviado el:* martes, 30 de septiembre de 2014 17:33
*Asunto:* [GiDlist] Sequential Node Numbering
GID,
For example,
Thank you,
*Sujith Gowda H S*
Germany
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140930/67141490/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140930/67141490/attachment-0001.jpg
amit Dhankhar
[GiDlist] duplicating nodes in GID
Post by amit Dhankhar »
I am having issues in created duplicate nodes at a given surface. I having
this kind of geometry-
[image: Inline image 1]
which is basically four small volumes. I'm trying to duplicate nodes among
a common sharing surface (to represent a crack surface) but GID is not
creating duplicate nodes. For example, in the figure, if I create a mesh
with one cell along each edge (structured mesh option) it yeilds 18 nodes
(9 at top and 9 at bottom) but it should have given me 4 extra nodes (i.e
total of 22 nodes) if I chose duplicate nodes. Any leads why this might be?
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141003/ad68ca87/attachment-0001.htm
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141003/ad68ca87/attachment-0001.png
You are right, duplicate nodes is broken in current GiD versions, and nodes become not duplicated!!
Temporary you can download and try the version GiD 10.0.9 (can get a free trial password in the web), with this version this tool already works.
We will fix the bug for next GiD 12 versions.
Enviado el: viernes, 3 de octubre de 2014 14:58
Asunto: [GiDlist] duplicating nodes in GID
I am having issues in created duplicate nodes at a given surface. I having this kind of geometry-
Inline image 1
which is basically four small volumes. I'm trying to duplicate nodes among a common sharing surface (to represent a crack surface) but GID is not creating duplicate nodes. For example, in the figure, if I create a mesh with one cell along each edge (structured mesh option) it yeilds 18 nodes (9 at top and 9 at bottom) but it should have given me 4 extra nodes (i.e total of 22 nodes) if I chose duplicate nodes. Any leads why this might be?
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141008/d3a5335f/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141008/d3a5335f/attachment.jpeg
amit Dhankhar
Thanks for letting me know about the bug. Just one question- since I can't
duplicate nodes, there is no way to represent a crack in the latest GID
version, right? Or is there can be some other way we can implement this.
Thank you
Amit
On Wed, Oct 8, 2014 at 7:54 AM, Enrique Escolano escolano at cimne.upc.edu
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *amit Dhankhar
*Enviado el:* viernes, 3 de octubre de 2014 14:58
*Asunto:* [GiDlist] duplicating nodes in GID
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141009/80befdb6/attachment.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141009/80befdb6/attachment.jpg
Without using any special ‘Duplicate nodes’ tool you must manually duplicate the geometric entities to have two surfaces (and its lines and points) on each side of the crack, and then each one will generate its nodes (but these nodes won’t be exactly in the same amount and location for both entities).
But it is easier to have only a single surface (and its lines and points) and apply the duplicate nodes mesh condition to left this task to the mesher.
I recommend you to temporary install also the 10.0.9 version, it takes five minutes, until the new 12 fixed version will be fixed
Enviado el: jueves, 9 de octubre de 2014 19:35
Asunto: Re: [GiDlist] duplicating nodes in GID
Thanks for letting me know about the bug. Just one question- since I can't duplicate nodes, there is no way to represent a crack in the latest GID version, right? Or is there can be some other way we can implement this.
Thank you
Amit
On Wed, Oct 8, 2014 at 7:54 AM, Enrique Escolano escolano at cimne.upc.edu wrote:
Inline image 1
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141009/8d18f1a5/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141009/8d18f1a5/attachment.jpeg
amit Dhankhar
Yes, the duplicate node feature works for the version you mentioned. Would
it be possible to have some kind of timeline when the bug would be fixed in
v12? Also if not, I have a full 1 year version v12, is it possible to
convert this into the 10.0.9 version in which this feature works? As the
number of nodes are restricted to only 1000 and surfaces to 25 in the
evaluation version.
Thanks!
On Thursday, October 9, 2014, Enrique Escolano escolano at cimne.upc.edu
both entities).
mesher.
javascript:_e(%7B%7D,'cvml','gidlist-bounces at listas.cimne.upc.edu');
javascript:_e(%7B%7D,'cvml','gidlist-bounces at listas.cimne.upc.edu');] *En
*Enviado el:* jueves, 9 de octubre de 2014 19:35
javascript:_e(%7B%7D,'cvml','gidlist at listas.cimne.upc.edu');
*Asunto:* Re: [GiDlist] duplicating nodes in GID
Thank you
Amit
Amit
javascript:_e(%7B%7D,'cvml','GiDlist at listas.cimne.upc.edu');
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141025/9cc0a691/attachment.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141025/9cc0a691/attachment.jpg
If you are using Windows platform you are lucky, you can download now two fixed versions:
the 12.0.2 official version, and the 12.1.1d developer version. Both are available for x32 and x64 bits
I recommend you to try the developer version, it has this fixed bug and new features, like STEP format export.
About the Linux version and the first Mac OS X GiD 12 version they will be available soon (maybe today or in few days)
http://www.gidhome.com/download
Enviado el: sábado, 25 de octubre de 2014 9:20
Yes, the duplicate node feature works for the version you mentioned. Would it be possible to have some kind of timeline when the bug would be fixed in v12? Also if not, I have a full 1 year version v12, is it possible to convert this into the 10.0.9 version in which this feature works? As the number of nodes are restricted to only 1000 and surfaces to 25 in the evaluation version.
Thanks!
On Thursday, October 9, 2014, Enrique Escolano escolano at cimne.upc.edu wrote:
De: gidlist-bounces at listas.cimne.upc.edu javascript:_e(%7B%7D,'cvml','gidlist-bounces at listas.cimne.upc.edu'); [mailto:gidlist-bounces at listas.cimne.upc.edu javascript:_e(%7B%7D,'cvml','gidlist-bounces at listas.cimne.upc.edu'); ] En nombre de amit Dhankhar
Para: gidlist at listas.cimne.upc.edu javascript:_e(%7B%7D,'cvml','gidlist at listas.cimne.upc.edu');
Thank you
Amit
On Wed, Oct 8, 2014 at 7:54 AM, Enrique Escolano escolano at cimne.upc.edu javascript:_e(%7B%7D,'cvml','escolano at cimne.upc.edu'); wrote:
Inline image 1
Amit
GiDlist at listas.cimne.upc.edu javascript:_e(%7B%7D,'cvml','GiDlist at listas.cimne.upc.edu');
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141027/d3c54b4a/attachment-0001.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141027/d3c54b4a/attachment-0001.jpeg
amit Dhankhar
I am using the linux version. My question is, can I just install it again
with my current licence when it's available (and would a note be placed on
the website http://www.gidhome.com/download when it is updated)?
thanks!
On Mon, Oct 27, 2014 at 4:33 AM, Enrique Escolano escolano at cimne.upc.edu
fixed versions:
*Enviado el:* sábado, 25 de octubre de 2014 9:20
evaluation version.
Thanks!
both entities).
mesher.
Thank you
Amit
Amit
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141027/d1a179d9/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20141027/d1a179d9/attachment-0001.jpg
