[GiDlist] Evaluation Version
Ali Ghavam Nasiri
Post by Ali Ghavam Nasiri »
Hello GiDs,
Does GiD considers an expiry date for the data files (models) created with Evaluation Version? I have been using the Evaluation Version for almost 1 year for academic purposes, but now I have a problem with GiD. It does not work on my existing data files which are nearly 2 months old (or more).
I have this problem both on Windows (8 pro) and Linux (Ubuntu). My files were originally created using GiD 11.0.5 on Windows. I also tried 11.0.6, 11.0.8, and 12.0.1 but it was unsuccessful.
I am now using GiD 11.0.8 which is working properly if I want to make new files and modify these new files, but I am not able to modify any of my old data files and I have to make the model from scratch.
On Linux I use GiD 11.0.7 but now it gives a permission error ( it says access denied to some file) after I press calculate button.
Kind regards,
Ali Ghavam-Nasiri
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140910/f2efbd9a/attachment.htm
David R. José
[GiDlist] View Results
Post by David R. José »
Hello!In my analysis there is a result that is given directly on nodes.Is there a way I can view them directly on the nodes without GiD interpolating them to the element?E.g.: I don't want a colored element. I want colored nodes with only the pure values given.
Thanks in advance!
David
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140911/5f7f9c8c/attachment.htm
amelendo
Post by amelendo »
Hello Ali Ghavam-Nasiri,
GiD do not have any expiration date on data files. Any GiD equal or
newer than GiD 11.0.5 must open all your files.
Could you send me and example to my private mail to check what is the
problem: amelendo at cimne.upc.edu
kind regards,
Adrià from GiD Team
El 11/09/2014 6:25, Ali Ghavam Nasiri escribió:
Hello GiDs,
Kind regards,
Ali Ghavam-Nasiri
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140912/1f0c2bea/attachment.htm
anna
Post by anna »
Hello David,
In order to see only the nodes colored you can change the display style
to "Points" or to "Points Bound".
You can change it through top menu "Window-View Style..."
In these cases only the nodes are displayed. You can find more options
related with the nodes display through top menu
"Options-Geometry-Point options..."
El jueves, 11 de septiembre de 2014 23:36:56, David R. José escribió:
Hello!
Thanks in advance!
David
*Anna Monros Bellart*
AVISO IMPORTANTE
AVÍS IMPORTANT
del CIMNE. Es poden exercir els drets d'accés, rectificació,
cancel•lació i oposició, per escrit a les nostres oficines del CIMNE,
IMPORTANT NOTICE
Mohamed Niyaz
[GiDlist] Error in meshing
Post by Mohamed Niyaz »
I am using GiD12.0.1 in my system. I create models of 3d structures in GiD.
Once I started doing meshing the screen automatically closes and I used to
get a message as segmentation fault (code dumped). How to rectify this
error. Please help me.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140917/ded79191/attachment.htm
It happen meshing all models or only with some model? Then send us the model and specify your main meshing options
Or if the model or the mesh is too big maybe there is not enough physical memory to handle it.
Which is your operating system? Windows or Linux? X32 or x64? Which distribution and version in case of Linux (e.g. Ubuntu x.x, Debian, …)
Maybe there is some problem with your graphic card. Try both modes: fast and safe visualization mode (Utilities-Preferences – Graphical - system )
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mohamed Niyaz
Enviado el: miércoles, 17 de septiembre de 2014 7:30
Asunto: [GiDlist] Error in meshing
I am using GiD12.0.1 in my system. I create models of 3d structures in GiD. Once I started doing meshing the screen automatically closes and I used to get a message as segmentation fault (code dumped). How to rectify this error. Please help me.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140917/7193f859/attachment.htm
Mohamed Niyaz
Dear Enrique Escolano
Thanks for the reply to my earlier mail. I have changed the visualization
mode and now meshing is working.
NIYAZ
On Wed, Sep 17, 2014 at 3:33 PM, Enrique Escolano escolano at cimne.upc.edu
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *Mohamed Niyaz
*Enviado el:* miércoles, 17 de septiembre de 2014 7:30
*Asunto:* [GiDlist] Error in meshing
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140918/90865b1d/attachment.htm
