[GiDlist] problem about scale factor of deformed mesh
Gangjin Li
Post by Gangjin Li »
Hi, all,
I am wondering if it is possible to set different scale factors for
deformation mesh in two directions, i.e. x and y, of a 2D picture in GID.
If the answer is yes, how to achieve it? As far as I understand, it seems
GID can only assign an uniform scale factor for both directions in the same
picture. Is it right? Many thanks in advance for the help.
Bests,
Gangjin
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140630/b7a40041/attachment.htm
The deformation factor scale is a single uniform value.
Maybe it is interesting for you to know that the 'Copy' window in
postprocess could do a 'Scale' transformation of the mesh, with different
scale values on each x, y, z direction
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Gangjin Li
Enviado el: lunes, 30 de junio de 2014 15:23
Asunto: [GiDlist] problem about scale factor of deformed mesh
Hi, all,
deformation mesh in two directions, i.e. x and y, of a 2D picture in GID. If
the answer is yes, how to achieve it? As far as I understand, it seems GID
Bests,
Gangjin
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140630/04359bc8/attachment.htm
Gangjin Li
Thank you so much, Enrique. Your reply is helpful for me.
Gangjin
On Mon, Jun 30, 2014 at 10:37 AM, Enrique Escolano escolano at cimne.upc.edu
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *Gangjin Li
*Enviado el:* lunes, 30 de junio de 2014 15:23
*Asunto:* [GiDlist] problem about scale factor of deformed mesh
Hi, all,
Bests,
Gangjin
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140630/eb4a96f9/attachment.htm
Gangjin Li
Hi, Enrique,
I checked the reference manual and GID itself. It seems the 'scale
transformation' is only accessible in pre-process rather than
post-process...Is there any other way in which the deformation mesh with
different scale factors in two directions in post-process stage can be
achieved? I will appreciate your help.
Gangjin
Gangjin
Hi, all,
Bests,
Gangjin
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140701/27a591af/attachment.htm
The transformation scale is also in postprocess in latest GiD versions,
download the 11.1.9.d developer version
http://www.gidhome.com/download/developer-versions
In doesn’t exists any other option to scale the postprocess mesh
Enviado el: miércoles, 2 de julio de 2014 3:40
Asunto: Re: [GiDlist] problem about scale factor of deformed mesh
Hi, Enrique,
Gangjin
Gangjin
Maybe it is interesting for you to know that the ‘Copy’ window in
postprocess could do a ‘Scale’ transformation of the mesh, with different
Hi, all,
Bests,
Gangjin
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140702/4978ae65/attachment.htm
