[GiDlist] GiD 11.0.6 crashing with tetgen
Mark Smith
Post by Mark Smith »
Hi GiD team,
When I mesh the attached simple geometry using tetgen with a mesh size of 0.085 then all is OK changing this to 0.06 or smaller causes GiD to crash?
Are there any work arounds?
I often find the advancing front method to be problematic.
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140422/d2d93200/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140422/d2d93200/attachment.obj
Hello Mark,
I have tried with the version 11.0.6 Win x32 with your model meshing
parameters and it worked well, with size 0.085 and also 0.06
Maybe the problem only happen in other platforms?
It exists also a more recent version 11.0.7 official version, and a 11.1.8d
developer version. It also fail with the latest versions?
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mark Smith
Enviado el: martes, 22 de abril de 2014 16:53
Para: GiDlist
Asunto: [GiDlist] GiD 11.0.6 crashing with tetgen
Hi GiD team,
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140422/959d4649/attachment.htm
Mark Smith
Hi Enrique,
I should have added that my version is win x64 installed using
GiD11.0.6-win-x64-Install.exe
Mark
To: gidlist at listas.cimne.upc.edu; 'Mark Smith' piedycat at yahoo.com
Sent: Tuesday, April 22, 2014 7:51 PM
Subject: Re: [GiDlist] GiD 11.0.6 crashing with tetgen
Hello Mark,
I have tried with the version 11.0.6 Win x32 with your model meshing parameters and it worked well, with size 0.085 and also 0.06
It exists also a more recent version 11.0.7 official version, and a 11.1.8d developer version. It also fail with the latest versions?
De:gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mark Smith
Para: GiDlist
Hi GiD team,
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140423/7c9cfc2f/attachment.htm
Hi Mark,
I have more information about this bug,
It is not related to x32 or x64 platform, it is related with
parallelization.
It crash when meshing volumes in GiD with Tetgen with more than 1 thread,
can avoid this crash setting
Utilities-Preferences – General – Other: Number of threads to use: 1
Enviado el: miércoles, 23 de abril de 2014 12:00
Asunto: Re: [GiDlist] GiD 11.0.6 crashing with tetgen
Hi Enrique,
Mark
Hello Mark,
Para: GiDlist
Hi GiD team,
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140423/bcae6210/attachment.htm
Mark Smith
Hi Enrique,
Thanks you for finding the problem. Does having more than 1 thread affect any of the other meshing routines.
Mark
Sent: Wednesday, April 23, 2014 7:27 PM
Hi Mark,
It is not related to x32 or x64 platform, it is related with parallelization.
It crash when meshing volumes in GiD with Tetgen with more than 1 thread, can avoid this crash setting
Hi Enrique,
Mark
Hello Mark,
Para: GiDlist
Hi GiD team,
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140424/37b581c0/attachment.htm
This bug has been avoided for next GiD version.
Nowadays we have only parallelized the loop of mesh volumes.
Maybe could be some other problems unknown by us, let us know if do you detect any more.
In the future we will try to parallelize also the loop of mesh surfaces.
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mark Smith
Enviado el: jueves, 24 de abril de 2014 14:35
Hi Enrique,
Mark
Hi Mark,
Hi Enrique,
Mark
Hello Mark,
Para: GiDlist
Hi GiD team,
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140424/01eece06/attachment-0001.htm
Mark Smith
Hi Enrique
For the next version do you mean GiD 12 ?
Mark
Sent: Thursday, April 24, 2014 2:19 PM
Hi Enrique,
Mark
Hi Mark,
Hi Enrique,
Mark
Hello Mark,
Para: GiDlist
Hi GiD team,
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140424/6e7db327/attachment.htm
By next version I mean all version after today,
could be 11.0.8 official and 11.1.9d developer if we compile some 11.x version more, and 12.x off course
Enviado el: jueves, 24 de abril de 2014 16:03
Hi Enrique
Mark
Hi Enrique,
Mark
Hi Mark,
Hi Enrique,
Mark
Hello Mark,
Para: GiDlist
Hi GiD team,
Mark
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140424/521d3336/attachment-0001.htm
Julia Camargo
[GiDlist] Number of nodes in a slice
Post by Julia Camargo »
Hi GiD support,
I usuallly work with semi-structured meshes. I'm trying to think in a way
to select the nodes in a slice, and export the number of those nodes. The
problem is that I don't have the equation of that plane, because the plane
that I want depends on the mesh that will be generated and depend also on
the shape of the object. Maybe I was not clear. I made a ppt that could
help you visualize my problem.
Thank you,
Julia
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140429/ba1d62e1/attachment-0001.htm
Name: nodes of slice.pptx
Type: application/vnd.openxmlformats-officedocument.presentationml.presentation
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140429/ba1d62e1/attachment-0001.bin
You cannot get easily the list of nodes of some ‘intermediate slice’ of a semi-structured mesh.
As you noted the slice is not a plane, and you cannot be able to get in a robust way its nodes by its geometrical location.
What you can do is something like this:
1- Mark the master surface of a top with a problemtype condition over surfaces-over nodes, to know these nodes of the ‘first slice’.
2- Mark the semi-structured volume with another condition over volumes-over body elements, to know the elements of the semi-structured mesh
3- Whit the previous information you could be able find the information you want: from the nodes of the first stile can use the element connectivities the find the nodes of the next slice, and so one. (must do it with some auxiliary exe or programming a Tcl procedure)
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Julia Camargo
Enviado el: martes, 29 de abril de 2014 16:05
Asunto: [GiDlist] Number of nodes in a slice
Hi GiD support,
I usuallly work with semi-structured meshes. I'm trying to think in a way to select the nodes in a slice, and export the number of those nodes. The problem is that I don't have the equation of that plane, because the plane that I want depends on the mesh that will be generated and depend also on the shape of the object. Maybe I was not clear. I made a ppt that could help you visualize my problem.
Thank you,
Julia
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140429/e58aa6eb/attachment.htm
