[GiDlist] GiDlist Digest, Vol 41, Issue 4
Deepak Samal
Post by Deepak Samal »
Thanks for your reply Enrique. But I didn't get your point. As far as I
know, Conditions in GID are applied for load or boundary assignments. Can
the conditions be used for assigning elements too to a particular set of
materials. Actually I'm quite new to GID and I'm sure there is some other
technique to do that but I'm unable to figure it out. Hope I have made my
doubt comprehensible.
On Tue, Dec 31, 2013 at 4:30 PM, gidlist-request at listas.cimne.upc.eduwrote:
or, via email, send a message with subject or body 'help' to
than "Re: Contents of GiDlist digest..."
Today's Topics:
1. Regarding loop over elements (Deepak Samal)
2. Re: Regarding loop over elements (Enrique Escolano)
Message: 1
Date: Mon, 30 Dec 2013 16:41:59 +0530
Subject: [GiDlist] Regarding loop over elements
Message-ID:
CACU__40tX5iKT37j3WZDqgaA-qPD8edTVf5LZjRcy19pkbZqww at mail.gmail.com
Content-Type: text/plain; charset="iso-8859-1"
Dear All,
I have to assign a set of elements each time to different materials. I have
around 60 different materials and around 9000 elements. Problem is
previously I was assigning elements by creating different layers for
different materials and assigning elements by using loop over elements by
setting the corresponding layer ON. But now I'm in a fix whether I should
be creating 60 different layers for 60 different materials and assigning
them the corresponding elements or is their any better way to do that?
Thank you
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131230/7e682765/attachment.html
Message: 2
Date: Mon, 30 Dec 2013 13:06:11 +0100
Subject: Re: [GiDlist] Regarding loop over elements
Message-ID: 003601cf0557$87daa2a0$978fe7e0$@cimne.upc.edu
Content-Type: text/plain; charset="us-ascii"
I don't understand well your case.
Are you trying to calculate the same model several times changing every
time
the kind of material?
you can create a Tcl procedure to automatize tasks. With Tcl-GiD commands
you can ask for the current model properties (layers, materials, entities,
etc) or you can change this propertities (assing materials or conditions ,
create entities, etc.)
This procedure could be set as a 'macro' to be invoked from an icon of the
'macro toolbar'
Are you using your own problemtype or a third part problemtype?
If you are developing your own problemtype maybe you can change your
approach, and instead a 'GiD material' could use a 'GiD condition' and
instead of define this condition as 'over body elements' and apply it to
each one of its elements could define the condition as 'over layer' or
using
last GiD 11.1.x versions as 'over group' and then you can set once the
entities of the layer or group and to apply the condition (that represent
your material) it is necessary to select only a layer or group name.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Deepak Samal
Enviado el: lunes, 30 de diciembre de 2013 12:12
Asunto: [GiDlist] Regarding loop over elements
Dear All,
be
creating 60 different layers for 60 different materials and assigning them
Thank you
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131230/c1eb943c/attachment-0001.htm
End of GiDlist Digest, Vol 41, Issue 4
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140101/734447c0/attachment.htm
To store the material properties for the analysis you can use
a) A ‘GiD material’
b) A ‘GiD condition’
A condition is really a data container that could be attached to geometry
or mesh entities, then you can use it to attach ‘material properties’
Enviado el: miércoles, 1 de enero de 2014 7:11
Asunto: Re: [GiDlist] GiDlist Digest, Vol 41, Issue 4
Today's Topics:
Message: 1
Message-ID:
Dear All,
Thank you
URL:
attachment.html
Message: 2
Are you trying to calculate the same model several times changing every time
'macro toolbar'
each one of its elements could define the condition as 'over layer' or using
Dear All,
setting the corresponding layer ON. But now I'm in a fix whether I should be
Thank you
URL:
attachment-0001.htm
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140101/713ee466/attachment.htm
Deepak Samal
[GiDlist] GiDlist Digest, Vol 42, Issue 1
Thanks for your Advice Enrique. I will work on the procedure you mentioned
and see where I get.
Thanks for your time.
On Wed, Jan 1, 2014 at 4:30 PM, gidlist-request at listas.cimne.upc.eduwrote:
Today's Topics:
1. Re: GiDlist Digest, Vol 41, Issue 4 (Deepak Samal)
Message: 1
Date: Wed, 1 Jan 2014 11:41:01 +0530
Subject: Re: [GiDlist] GiDlist Digest, Vol 41, Issue 4
Message-ID:
CACU__43GFrTa24aCEegy9CWndcgcTuUF1pm9KzuncpL0s69wBA at mail.gmail.com
Today's Topics:
Message: 1
Message-ID:
Dear All,
have
Thank you
URL:
Message: 2
time
entities,
the
'macro toolbar'
using
Dear All,
have
be
them
Thank you
URL:
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140101/734447c0/attachment.html
End of GiDlist Digest, Vol 42, Issue 1
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140102/af8564fe/attachment-0001.htm
