[ GiDlist ] load vector
Sebastian Skatulla
Post by Sebastian Skatulla »
another question, can GID create a load vector, i.e. in the *.cnd file I
define a load condition as follows:
condtype: over lines
condmeshtype: over nodes
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
then I assign to one boundary line (l = 1m) of a rectangle this line
load . Does each of this 5 node of the boundary line after meshing get
0.25 kN(inner nodes) / 0.125 (outer nodes)? Or simply 1.0 kN/m? It seem
to be the last one.
Sebastian
Mohamed Abdalla Abdel-Meguid
Post by Mohamed Abdalla Abdel-Meguid »
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
to be the last one.
yes you can,
The way I used to define the force vector is as follow:
in the .cdn file you can add a condition of point-load or face-load
as you mentioned above with whatever default value you wish.
I did not try to add units in there.
usually when I am writing or modifying the configuration files, I used to
look at one of the example files provided. You can do the same if you
wish.
M.A.Meguid
UWO, Canada
Sebastian
Javier Mora
Post by Javier Mora »
For structural analysis, it could be very useful to take a look to the
configuration files of calsef (www.cimne.upc.es/calsef), the GiD+ module for
this kind of simulations.
-----Original Message-----
[mailto:owner-gid at gatxan.cimne.upc.es]On Behalf Of Mohamed Abdalla
Abdel-Meguid
Sent: Tuesday, August 22, 2000 6:24 PM
Subject: Re: [ GiDlist ] load vector
*.cnd file I
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
this line
meshing get
kN/m? It seem
to be the last one.
yes you can,
files, I used to
wish.
M.A.Meguid
UWO, Canada
Sebastian
Ramon Ribó Rodríguez
Post by Ramon Ribó Rodríguez »
It is possible to define condition values that change depending on the x,y
and z coordinates. It would be the typical case for applying a triangular or
parabolic load to a boundary of the model.
To do so, check the type of field #FUNC# in the problem type conditions
help.
About the planar surfaces, they are being completely substituted by the
NURBS surfaces. It is better to use these.
ccondtype: over lines
question: x1
value: 1.0 kN/m
question: x2
value: 0.0 kN/m
to be the last one.
Sebastian
Numèrics en Enginyeria
C/ Gran Capitan s/n,
