Thank you for your answer.
I use Gid with tochnog. First, i want to replicate in Gid the example number 17 of the manual user of tochnog. I drew: circle (center 5,5,0 normal 0,0,1 radius 5) and rectangle (line 0,0,0 - 10,0,0 - 10,-3,0 - 0,-3,0 - 0,0,0). When I select the line of the circle and the supperior line of the rectangle to create a contact of surface and when I push on the key escape, Gid displays the message:
Created 0 new contact surfaces. Can continue (ESC to leave).
Leaving contact creation.
I have study this example directly with tochnog and I visualize the result with Gid without problem (post processor).
The same message is displayed with the case that I wrote in my first message (volume contact).
This message is displayed in Gid 5.0p47 and Gid 5.0p49b2.
Is there something certainly that I didn't understand in the creation of contacts, but what?
----- Message d'origine -----
De : ramsan at stamp.cimne.upc.es
À : gidlist at gatxan.cimne.upc.es
Envoyé : mardi 21 mars 2000 17:04
Objet : [ GiDlist ] contact in GiD
Where is the problem? In order to understand correctly the problem,
it is necessary for me to know which kind of analysis program are
you using to make the calculation and what are the requirements of
this program related to the contacts.
pachevalier at netcourrier.com writes:
I use GiD without difficulties to calculate some mechanical parts. I wish to calculate a contact between a cylinder and a plate thick to study in 3
measurements the pressure of hertz. I don't manage to simulate this contact between two strong at all.
The example that me to treat is a cylinder of diameter 20 , of length 30 mm submitted to a strength of 5000 N and in contact on a plate of 40 x 40 mm, thickness 20 mm.
Is someone able to explain me the step-by-step gait to calculate this contact?
Thank you for your help.
Patrick Chevalier
France
Tél : 08 36 69 00 21
Centre Internacional de Mètodes Ramon Ribó
Numèrics en Enginyeria
ramsan at cimne.upc.es
C/ Gran Capitan s/n,
Contacts in GiD and contacts in tochnog are not the same thing. You
should ask a tochnog expert in order to learn to create this
contact for this problem.
