[ GiDlist ] Meshless Methode
Miguel A. de Riera Pasenau
The format to write the post process information on point elements
is explained in the reference manual, and also at
http://gid.cimne.upc.es/support
under the 'GiD on-line' manual, 'POSTPROCESS DATA FILES' section
( http://gid.cimne.upc.es/support/gid_16.html#SEC222 )
Once, the postprocess files are read,
using the 'point options' window, which can be found
in the 'options' menu, 'Geometry' submenu, 'point options' entry,
the quality and size of the points can be controled.
And the results can be viewed using 'Contour fill', 'Vectors', deformations, etc.
Hope it helps,
Enrique Escolano wrote:
Oriented to the meshless methods of analysis:
On the one hand, GiD can generate in a volume a cloud of points,
(see Meshing-Elem type-Only points)
as well as a mesh of triangles in the contour to provide the normal ones.
On the other hand, it can graphically postprocess the results in these
points.
From: "Sebastian Skatulla" sebastian at skatulla.com
To: "GiDList" gidlist at gatxan.cimne.upc.es
Sent: Friday, March 02, 2001 12:43 PM
Subject: [ GiDlist ] Meshless Methode
in a representation paper about GID I read that GiD support the Meshless
Methode. But I cant find any information in the user manual?!
Sebastian Skatulla
Sebastian Skatulla
AW: [ GiDlist ] Meshless Methode
Post by Sebastian Skatulla »
thanks for reply.
is explained in the reference manual.
Yes I found it. But I need the meshless feature for preprozessing. There is
a newer analysis methode than the finite elements methode called 'mesh free
methode' and for which the solver only needs points and a influence zone of
these points - not a node-elment-mesh.
This, I think, isnt supported by GID, or?
Sebastian Skatulla
