Dear Pablo,
In general in GEOSTAR you can plot "faster" shaded Shell elements mesh without geometry associated, but the hidden line algorithm is not always successful in plotting the elements correctly, especially for 3D solid models (Bricks & Tetras), so different techniques can be used to correct the displays.
Yesterday I explained "to remove geometry association" of the elements during the plotting process, but also the z-buffer algorithm (Display Display_Option Set Hide Option) will usually do the trick of correcting the hidden line plot. The z-buffer algorithm is more robust but is much more CPU intensive and can take relatively long times for display especially for large models.
The z-buffer algorithm along with the removal of geometry will always solve any plotting problems for 3D solid elements !!
Cheers!,
Blas.
Blas Molero Hidalgo
Director
Tecnologías CAE Avanzadas, S.L.
Parque Tecnológico de Zamudio - Edificio Central, nº 101
48170 Zamudio (SPAIN)
Tel. +34 94 420 93 54
Fax. +34 94 420 93 55
E-mail: Blas.molero at tecnocae.es
WEB: http://www.tecnocae.es
Desde: Pablo Perez del Castillo
Enviado el: viernes 26 de enero de 2001 3:42
Asunto: Re: [ GiDlist ] troubles with meshview
Thanks Blas, i will try, with shell elements export without geometry i never have troubles.
Pablo
=?iso-8859-1?Q?Blas_Molero_=2D_Tecnolog=EDas_CAE_Avanzadas?= escribió:
Dear Pablo,
In COSMOS/M Geostar you don´t see anything when plotting elements because the mesh is not associated to geometry, the information you can import from GiD is only nodes & elements, not the geometry (Curves, Surfaces, etc..).
You can display mesh simply issuing the following commands:
. "BOUNDARY,1,0" command from "Display, Display_Option, Set Bound Plot" to plot boundary element faces only not associated with a surface or region
. "EVAL_BOUND,1,0,20,1" command from "Display Display_Option Eval Element Bound" to evaluate boundary faces,
. "SHADE;" command to activate shading of element plots, and finaly
. "EPLOT;" command to plot ALL elements.
You have this problem well explained in our COSMOS/M Support page in the following address:
http://www.tecnocae.es/soporte/cosmosm/display.htm
Blas.
Blas Molero Hidalgo
Director
Enviado el: jueves 25 de enero de 2001 3:31
Asunto: [ GiDlist ] troubles with meshview
Hi to everybody
When i generate tetrahedra elements, then meshview does not work, so i can see
the mesh in normal mode, but when i do render filled nothing to see, and when i
export to cosmos it happens the same, i can see the mesh with no hidden, when i
try to render, nothing to see.
Anybody can help me .
advanced thanks
Part 1.2 Type: application/ms-tnef
Encoding: base64
Name: not available
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010126/622e662a/attachment.bin
