[GiDlist] surface mesh
Oguz Tanzer
Post by Oguz Tanzer »
This is yet another simple question(YASQ). How can you
save a surface mesh(of a sphere) when you see the
elements in "Boundary" mode? Or restating, how can you
create a surface mesh only(again for a sphere).
Regardless of the surface meshing option I choose, the
program creates, tetrahedra and meshes the whole
volume.
Tanzer
Do You Yahoo!?
Yahoo! Movies - coverage of the 74th Academy Awards®
http://movies.yahoo.com/
Post by Enrique Escolano »
1) By default, GiD mesh the volume (with tetrahedras) and not create the
surface elements (truiangles) for the boundary surfaces.
- If you delete the volume, then are generated the desired triangles.
- Also, you can force to not mesh the volume and mesh the surfaces whitout
delete the volume:
Meshing-MesCriteria-NoMesh-Volumes (and select the volumes to not mesh)
Meshing-MesCriteria-Mesh-Surfaces (and select the surfaces to force mesh)
2) If you only have a volume mesh, but not a geometry to re-mesh the
boundary surfaces,
you can create the boundary triangle elements with "Meshing CreateBoundary"
(this option is only available with the right buttons, hidden by default).
Note: this is different of "Meshing Boundaries" that only visualize the
boundary, but not create triangles.
Sent: Thursday, March 28, 2002 2:13 PM
Subject: [GiDlist] surface mesh
volume.
Tanzer
Do You Yahoo!?
