[GiDlist] (no subject)
Ricardo Resende
Post by Ricardo Resende »
I'm getting this window when I try to run GID (it's the same in all versions). I'm running windows 2000 and it used to run OK.
Can you give me some advice?
Ricardo Resende
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020321/88a38e90/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020321/88a38e90/attachment.jpeg
Name: Ricardo Pontes Resende.vcf
Type: text/x-vcard
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020321/88a38e90/attachment.vcf
Post by Enrique Escolano »
Tipically, these type of problems are caused by the graphics acceleration card.
A possibility to avoid the problem is the following:
Try to start GiD safe mode (from the start menu) and activate use Software OpenGL
If the problem persists, try to deactivate the graphic hardware acceleration
(Screen properties-Advanced options).
Also try a different colour resollution (select 32 bits of colour for example)
Search in the web page of your card if there are actualized drivers for your graphic card.
The GiD Team
Sent: Thursday, March 21, 2002 1:19 PM
Ricardo Resende
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020321/84cae3e0/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020321/84cae3e0/attachment.jpeg
