[GiDlist] postprocess calculation
Mark Smith
Post by Mark Smith »
Win98 GiD6.2.0d
Sorry to be a nuisance but my code (red):
proc InitGIDProject { dir } {
global VarAuxPriv
set VarAuxPriv(DirProblemType) $dir
CreateMenu "Flight" "PRE"
InsertMenuOption "Flight" "Calc 1" 0 "run_1" "PRE"
RemoveMenuOption "Help" "Tutorials" "PREPOST"
RemoveMenuOption "Help" "What is new ..." "PREPOST"
RemoveMenuOption "Help" "FAQ" "PREPOST"
InsertMenuOption "Help" "Help GiDBeM" 1 {HelpWindow "CUSTOM_HELP"
"E_BeM2.gid"} "PREPOST"
UpdateMenus
proc run_1 { } {
WarnWinText "EXECUTE: $VarAuxPriv(DirProblemType)/makemat.exe"
exec "$VarAuxPriv(DirProblemType)/makemat.exe"
proc EndGIDProject {} {
-------------does nothing when I press the Calc 1 button under the Flight
menu? No error messages, nothing?
The executable makemat.exe is in the problemtype directory and writes a file
into this directory.
Is there a list of all the GiD functions e.g. GiDVersionCmp and their
usage anywhere?
Thanks. Mark
-----Original Message-----
Sent: 19 March 2002 18:08
Subject: Re: [GiDlist] postprocess calculation
If run_1.exe is located inside the problemtype directory:
Save the parameter dir of InitGIDProjec in a global variable:e.g.
VarAuxPriv(DirProblemType) to use later this path.
You can use WarnWinText "text" to debug your tcl code
global VarAuxPriv
proc run_1 { } {
#this line WarnWinText must be commented
WarnWinText "EXECUTE: $VarAuxPriv(DirProblemType)/run_1.exe"
exec "$VarAuxPriv(DirProblemType)/run_1.exe"
+44 (0)1480302100
http://www.linx.co.uk/
person.
